Yeah all. I would like to hookup a cb that will come on/off with the key switch. Thinking about putting a relay under the hood with power coming off the battery controlled by an ignition switched wire. Is there a ignition switched spot on the fuse box under the hood?. If so with one?
Thanks all
Pretty sure fuse M7 is generally used for a switched source.
Yes I used a fuse tap and added a circuit for my sub amp turn on using M7.
Ok, a fuse tap can be picked up at an auto parts store? Thanks will look for M7 in the fuse box.
Thanks for the info.
Yes. JKU uses the smaller ATM fuses. Make sure to get the correct sized tap.
Not sure if everything worked out. But here are some snaps from the net
Not Mine
