1 - 20 of 25 Posts
i'm......... lost
i'm looking into lifting my jeep and putting some new wheels on. i'm pretty new to the whole mechanics aspect of it.. but i really enjoy what i understand so far.. i just want to know what you all think and maybe give me some advice.. tell me what will work with what and what else i need to do or something of that nature.
this is what i want to do.
starting with....
these tires
Pro Comp 55031 - Pro Comp Xtreme All Terrain Radial Tire - Quadratec
on these rims..
CRAGAR Wheels 3975712 - CRAGAR Series 397 Soft 8 Black Wheel for Jeep® Vehicles with 5x4.5 Bolt Pattern - Quadratec
and im pretty sure ive got them matched up... let me know if im dumb
with this lift..
Skyjacker 4" Economy Lift Kit with Hydro Shocks for 03-06 Jeep® Wrangler TJ - Quadratec
i think that should be okay for a while. im on a pretty tight budget haha i really wish i just had an insane amount of money to do this. but what do you think of that? is that okay to start off? do i need more? i've heard you can get some pretty bad vibrations and death wobbles and what not from lifting your jeep without getting a whole bunch of new stuff.. would i need like track bars and everything if i want to be secure on the road? and what about gears? should i upgrade them as well? lemme know whatcha think! i'm really excited to do this. i love my jeep :D
i'm......... lost
and what about engine mods? should i look into intakes and exhaust for more hp if im going to get into wheeling a bit more??
Jeeper
You sure you want to put 31's on a Jeep with 4" of lift? Bigger tires will look more proportional. But that means you'll want 15x8" wheels, not 15x7's, and as far as tires, look at some others and other places to purchase... I've heard Pro Comps wear very quickly, but have no experience with them myself. I love my Duratracs.... and I think pricewise you'll find they are comparable, if not less expensive. I can't comment about that lift, as I have no experience with it...
www.jegs.com has the best pricing I've found on soft 8's... and check your local tire dealers for pricing on wheels and tires... It's always nice to keep your $ local when possible... :)
i'm......... lost
yeah this was just like a guideline. i don't think ill actually be purchasing anything online unless i really have to.. i think i meant to link the 33" tires... oh yeah the link just brings you to the page. the tires i was trying to match were the LT285/75R16. that would look good, right?
i'm......... lost
oh i was lookin at the 16" wheels as well haha the ... 16x7 5 on 4.5"... not really sure what all those numbers mean. i understand the 16(height)x7(width) but not sure about the rest
Jeeper
The 5x4.5" is the bolt pattern. That is the correct pattern for a TJ (97-06) the bolt pattern for a JK (07+) is 5x5.... If the bolt pattern isn't correct for the application then adapters must be used, so make sure you buy the right bolt pattern. Also, the most common wheel width for a Wrangler application is 8" for up to a 12.5" wide tire. That width allows you to air down off road without so much worry loosing a bead. Any narrower will be to narrow for a tire wider than 10.5".....
Edit: As far as engine mods go, skip them. They don't help enough to justify the cost... :)
i'm......... lost
so in other words, go wider? haha. so the 16x8" 5 on 4.5" would be good for the 33.1x11.3"? i think im getting the wheels down :p
i'm......... lost
soo.. the 35x12.5 R15's on the 15x7 5 on 4.5's? again, this is just like a guideline.. but you think i should get 35's?
Keep in mind that sticking with a 15inch wheel will prob make your tires a little cheaper, maybe not in all cases but most
id go with a 33x12.5'' tire on a 15x8 rim with a 3.75 backspacing.. itll look like such.. and btw i dont have a 4'' lift
i'm......... lost
Discussion Starter · #14 ·
Gate53 said:
4 cyl or 6 cyl, auto or stick? How much experiance do you have offroad driving?
Inline 6, 6 speed manual. I really dont have that much experience.. I like to roam through the woods around my house. You think 4 inches would be too much? I feel like i cant go anywhere with my stock height.. Im afraid to try going bigger (like real off road trails) and that im going to crack an axle or bend a track bar or something like that
i could be wrong but i didnt think you could fit 35s on 4inch lift. plus you would probably want stronger axles if your going to wheel it.
Jeeper
You can go all sorts of places stock..... :) You need to get out there and wheel it, get stuck, then you'll know what you need for what you want to do... My TJ amazed us when it was stock..... it went everywhere the bigger boys went with no problem.... :)
i'm......... lost
Discussion Starter · #18 ·
I really appreciate all the feedback. Maybe ill just keep her stock for a bit.. Or go with the 33 on 15's as mentioned. Give it a bit more clearance..
35s can fit on a 4'' lift.. not recommended.. but itll work for a less serious offroader..
as for your comment you dont think you can go anywhere with your stock jeep.. have you tried? a stock jeep is amazing.. lifting it makes it even better..
for 33s.. go with a 3'' lift.. if you need more clearance.. add a bodylift.. a 4'' will cost a TON more than just the lift price.. you'll need adjustable control arms and a sye/ds
i'm......... lost
Discussion Starter · #20 ·
I guess i should just balls up and see how far my jeep can go? hah theres a pretty sweet trail ive been wanting to go down but too afraid i might get stuck haha
1 - 20 of 25 Posts
