1 - 20 of 21 Posts
I live in Idaho and am getting a '18 WRANGLER UNLIMITED SPORT 4X4 and now i'm a bit worried after reading all the issues people have had with an 2018 model.
I pick her up in about 3 days, and BEFORE I spend the coin, what should I look at specifically or what should I do to make sure I don't get a lemon!
I am not sure if I love California build code stuff. That state is beautiful, but some potential add-on stuff could be a pita to deal with...ON DIESEL. I don't know much about a car with gas engine...
Our plan is light off-roading and tow behind my truck camper. I plan to make a ton of posts about how we use the JL down the road...But first I want to make sure what to look for.
I DO know a recall was done.. #Y95 2018 JL STICTION - STEERING ASSIST ---- That's the only thing done and none are showing pending.
Here is the 2018 build sheet: I figure you guys might need to know about what's on her vs me answering 10k questions about much I don't know...
Anything you all can suggest would be greatly appreciated!
Tom
JL has 32,000 miles
STANDARD EQUIPMENT
  • * Single Top Package
  • * Monotone Paint
  • * Advanced Brake Assist
  • * Electronic Stability Control
  • * Hill Start Assist
  • * Traction Control
  • * Electronic Roll Mitigation
  • * Trailer Sway Damping
  • * Hydraulic Assist Brake Booster
  • * Anti-Lock 4-Wheel Disc Brakes
  • * Low Back Bucket Seats
  • * Reclining Front Seats
  • * Driver Height Adjuster Seat
  • * Rear 60/40 Folding Seat
  • * Child Seat Upper Tether Anchorage
  • * RR Head Restraints Outboard Seating
  • * Advanced Multistage Front Air Bags
  • * Supplemental Frt Seat Side Air Bags
  • * Front Seat Area Carpet
  • * Rear Seat/Wheelhouse/Cargo Carpet
  • * Cargo Tie Down Loops
  • * Sport Bar
  • * Three Rear Seat Head Restraints
  • * Front Seat Back Map Pockets
  • * Driver and Passenger Assist Handles
  • * Full Length Floor Console
  • * Rear Compartment Storage Tray
  • * Storage Tray
  • * Urethane Shift Knob
  • * Illuminated Cupholders
  • * Command-Trac Part Time 4WD System
  • * Dana M186 Front Axle
  • * 3.45 Overall Top Gear Ratio
  • * Conventional Differential Frt Axle
  • * Tinted Windshield Glass
  • * Front Door Tinted Glass
  • * Full Metal Doors w/Roll-up Windows
  • * Rear View Day/Night Mirror
  • * Sentry Key Theft Deterrent System
  • * Pushbutton Start
  • * Hood Insulation
  • * 120 MPH Primary Speedometer
  • * Silver Platinum I/P Bezels
  • * Outside Temperature Gauge
  • * Var Intermittent Windshield Wipers
  • * Dual Note Electric Horns
  • * 12V Auxiliary Power Outlet
  • * Auxiliary 12-Volt Rear Power Outlet
  • * Locking Glove Box
  • * Manual 2-Way Driver Lumbar Adjust
  • * Manual 6-Way Driver Seat
  • * Frt Pass Seat - Manual Adjust 4-Way
  • * Front Passenger Seat Belt Alert
  • * Vehicle Information Center
  • * Courtesy Lamps
  • * Front Dome w/On/Off Switch Lamp
  • * Black Exterior Mirrors
  • * Headlamp Off Time Delay
  • * Rear Dome w/On/Off Switch Lamp
  • * Halogen Headlamps
  • * Ft Side Marker/Side Repeater Lamp
  • * Front Fog Lamps
  • * CHMSL Lamp
  • * Molded Black Front Bumper
  • * Black Front Frame Overlay
  • * Body Color Grille
  • * Black Door Handles
  • * Silver/Black Trail Rated Badge
  • * Accent Color Fender Flares
  • * Jeep Badge
  • * Wrangler Sport Decal
  • * 21.5 Gallon Fuel Tank
  • * Speed Control
  • * Granite Crystal Met. Clear Coat
  • * Fixed Long Mast Antenna
  • * Steering Wheel Mounted Audio Ctrls
  • * Media Hub (USB, Aux)
  • * Audio Jack Input for Mobile Devices
  • * Remote USB Port
  • * Power Steering
  • * Normal Duty Suspension
  • * Front Stabilizer Bar
  • * Rear Stabilizer Bar
  • * Tilt/Telescope Steering Column
  • * Full Size Spare Tire
  • * Outside Tire Carrier
  • * Matching Spare Wheel
  • * ParkView Rear Back-up Camera
  • * Occupant Classification System
  • * Fuel Tank Skid Plate Shield
  • * Transfer Case Skid Plate Shield
  • * 2 Front & 1 Rear Tow Hooks
  • * Torx Tool Kit
  • * Transmission Skid Plate
  • * R1234YF A/C Refrigerant
  • * Tire Pressure Monitoring Display
  • * Tethered Fuel Filler Cap
  • * Fuel Filler Bezel - Black
  • * English/USA Language
  • * Protective Coating and Remover
  • * Base Interior Accents
  • * Bumper Module I
  • * Wheel Flare/DRL Parts Module
  • * Grille Module
  • * Door Trim Panel Module
  • * Center Console Parts Module
  • * Front Fascias Parts Module
  • * Seat Parts Module
  • * Instrument Panel Parts Module
  • * Door Parts Module
  • * Front End Parts Module
  • * Front Suspension Parts Module
  • * Rear Suspension Parts Module
  • * Tire & Wheel Parts Module
  • * Frame Parts Module
  • * Build To U.S. Mkt. Specifications
  • * GVW Rating - 5300#
  • * U.S. Dealer Retail
  • * Zone 71-Los Angeles
  • * Jeep Wave Owner Care (N/A Fleet)
  • * JL/5403 Vehicle Family
  • * Four Wheel Drive (4WD)/(4X4)
  • * Price Class L
  • * Left Hand Drive (LHD)
  • * 2018 Vehicle Specifications
  • * Four Door
  • * Vehicle Order Tracking
  • * Long Wheel Base (LWB)
  • * U.S. Specifications Label
  • * California Ship to State Code
  • * California Sold to State Code
  • OPTIONAL EQUIPMENT
  • * Cloth Low-Back Bucket Seats
  • * Black
  • * Technology Group
  • * Convenience Group
  • * Cold Weather Group
  • * Trailer Tow and HD Electrical Group
  • * Safety Group
  • * 240 Amp Alternator
  • * 700 Amp Maintenance Free Battery
  • * Aux Battery
  • * Hill Descent Control
  • * MOPAR Hardtop Headliner
  • * Freedom Panel Storage Bag
  • * MOPAR All-Weather Floor Mats
  • * All Automatic Transmissions
  • * 8-Spd Auto 850RE Trans (Make)
  • * Dana M220 Rear Axle
  • * Anti-Spin Differential Rear Axle
  • * 3.6L V6 24V VVT Engine Upg I w/ESS
  • * Deep Tint Sunscreen Windows
  • * Rear Window Defroster
  • * Sun Visors w/Illum Vanity Mirrors
  • * Power Heated Mirrors
  • * Remote Keyless Entry
  • * Air Conditioning w/Auto Temp Control
  • * Black 3-Piece Hard Top
  • * Cluster 7.0" TFT Color Display
  • * Rear Window Wiper/Washer
  • * GPS Antenna Input
  • * Air Filtering
  • * Speed Sensitive Power Locks
  • * Heated Front Seats
  • * Pwr Windows, Front 1-Touch Down
  • * LED Taillamps
  • * Aux Switches
  • * Automatic Headlamps
  • * Security Alarm
  • * Injection Molded Black Rear Bumper
  • * Side Steps
  • * 50 State Emissions
  • * Engine Oil Cooler
  • * Heated Steering Wheel
  • * All Radio Equipped Vehicles
  • * Alpine Premium Audio System
  • * 7.0" Touch Screen Display
  • * Apple CarPlay
  • * Google Android Auto
  • * USB Host Flip
  • * SiriusXM Satellite Radio
  • * Integrated Center Stack Radio
  • * Leather Wrapped Steering Wheel
  • * No Soft Top
  • * 245/75R17 All-Terrain Tires
  • * Bridgestone Brand Tires
  • * Uconnect 4 with 7" Display
  • * 17X7.5 Polished Granite Crystal Whls
  • * All Aluminum Wheels
  • * ParkSense Rear Park Assist System
  • * Blind Spot and Cross Path Detection
  • * Remote Start System
  • * Tip Start
  • * Class II Receiver Hitch
  • * 7 and 4 Pin Wiring Harness
  • * Universal Garage Door Opener
  • * Stop-Start Dual Battery System
  • * Non-Lock Fuel Cap w/o Discriminator
  • * Integrated Voice Command w/Bluetooth
  • * Jeep Trail Rated Kit
  • * SiriusXM Radio Service
  • * For More Info, Call 800-643-2112
  • * Manuf Statement of Origin
  • * 5 Additional Gallons of Gas
  • * Spring - Left Front
  • * Spring - Left Rear
  • * Spring - Right Front
  • * Spring - Right Rear
  • * Customer Preferred Package 2TS
  • * Customer Preferred Package 24S
  • * Sales Tracking
  • * Easy Order
  • * Priority Tracking
  • * United States Region Group
  • * NAFTA Region
06 TJ SE 2.4L 6spd, 79 CJ5 258ci 4spd, 83 CJ7 258ci auto
Many on here buy new or new to them Jeeps, I personally wouldn't hit a dog in ass with one for fear of it falling apart while watching the dog run away laughing the whole way...but that's me, I don't think anyone can predict what a used vehicle will do, especially not really knowing how the previous owner drove it, or maintained it. It might go 200,000 miles trouble free, or 1 block and kablooie lol. 2013 is my limit for a new Jeep, once Fiat and company got involved...cheap parts-overpriced
Any used vehicle is a crap shoot. You never know if the other person maintained it perfectly or never changed the oil once. The best you can do is look it over and check for any obviously things.
Retired Moderator
Welcome to the Forum! The 2018 JL, is one of the better year Wranglers. It has the awesome 8 speed Auto, along with the updated PUG 3.6 engine, without the e-torque crap add on. If you plan on keeping it long term, then there are extended MOPAR warranty policies available..your call..
My Grandson has a 2018 JLR, and we are very happy with it.
^^^ The above is a WF Vendor, that offers favorable pricing, for these policies.
Welcome from Arizona.
Discussion Starter · #11 ·
Round two and this one from Carmax (us vehicle) lasted 35 min after I bought it. Went on the freeway and stopped for a burger to find coolant pouring out of charged overflow reservoir. You guessed it, blown head gasket or crack in the block.
Carmax taking it back this am and all will be right with them. Really good company to deal with. Honestly
But now the search begins all over again.
Discussion Starter · #13 ·
Well, wife and I are beginning to wonder if ordering a new one might end better. We keep looking for under 30K miles , but it seems if there is low miles, they are traded like 3x. That has taught us to be extremely careful. CarFax has been invaluable.
We are prob going to do a Peterson deal with 6% off MSRP.
Make sure to the read the fine print.
As @Chugiakguy and I found out, the prices they quote normally include financing 90% of the vehicle’s value through their financial institution of choice, for the first six of so many payments.
You can ask for a cash quote as well. Chances are it won’t look nearly as sweet.
Does financing with them lock you into not paying it off early? Only asking because I’ve financed through places before to get an available ‘credit’ and have been asked by the dealer to not pay it off, but it’s never been locked… just paid it off or refinanced with my preferred lender before the first monthly payment was due.
Dbart, if I remember Peterson's deal correctly (and maybe Aldo can verify this), you are in fact locked into paying the first six monthly payments with them --- by which point you would have paid most of the interest of the loan, while having paid off almost none of the principle. In my case, it would have effectly added about $3000 to the purchase price. And if you ask for a cash price, with no financing, they will simply add that six month's worth of interest to your quote for the cash price, so there is essentially no avoiding paying most of the full interest on the loan, even if you finance it with them and then pay off the rest of the loan at the end of six months.
Discussion Starter · #19 ·
DONE!!!
We Skipped Peterson‘s in Boise and bought in Mountain Home and it’s really funny….. Peterson’s price AFTER THEIR AFFILIATE REBATES, was the same exact price as Mountain Homes price and the exact same price as MSRP. So, I honestly think Peterson’s was selling OVER MSRP. Guys, the numbers don’t lie. I feel like there was something fishy. I even verified the prices online and the only one with higher pricing, was PETERSON‘s.
I am blown away at how friendly and non-pressuring Mountain Home was.
RJay there is the man!
Peterson's quote last fall was very good...provided you were willing to finance 90% of the value of the vehicle through them. If you didn't, then there's nothing to see there.
1 - 20 of 21 Posts
