1 - 11 of 11 Posts
wow thats the cleanest jeep CJ i've ever seen and for 4g WOW what a deal
dont even tell me where it is or else ill end up with two cj's and no DD
Very clean. How much has it been restored? I am not sure that is the original paint scheme for the golden eagle. Other than that it looks great.
Discussion Starter #7
This is what the guy has to say about it in the AD.
1979 FACTORY GOLDEN EAGLE V8 304 3SPD. TILT WHEEL, NEW PAINT, RHINO LINER, BATTERY, REMAN ALT, NEW PLUGS, WIRES, FUEL PUMP, FUEL SENDER (NEEDS NEW GUAGE) NEW IGNITION MODULE, BATTERY CABLE, STARTER SEL SWITCH, BELTS, HOSES, HOLLEY CARB, EDELBROCK INTAKE, HEADERS, CHERRY BOMBS, MILD CAM, AIR CLEANER, NEW BRAKE MASTER CYLINDER. THIS JEEP SOUNDS AWESOME. JEEP HAD NEW METAL IN FLOORS AND SIDES. TIRES ARE SHOT. NEEDS FRONT U JOINTS. BIKINI TOP IS INCLUDED. NO HARDTOP. AS WITH ANY USED VEHICLE SOLD AS IS. JEEP HAS RANCHO 2.5" SPRING LIFT WITH RANCHO SHOCKS AND STEERING STABILIZER. I WILL ASSIST WITH SHIPPING. ALL GUAGES AND LIGHTS WORK EXCEPT FUEL GUAGE.
The new paint explains why the eagle colors are a little different. From the writeup it has had a moderate rebuild and still needs some work. If it is clean and the frame is solid then the $4k price should be about right. Take a ball peen hammer and tap on the frame. Mainly around the rear spring mount/tire area. Listen for changes in sounds. Does not sound like a bad deal.
also if you are actually reall interested and you know it has been repainted take a weak magnet and put it along the body, this way you can see how much bondo is on it,
but it seemed like just a dream, not that your really serious about buying it
Discussion Starter #10
Oh, I would LOVE to have it. But right now its just going to stay a dream till I start working again.
~Lev
Administrator
its that a metal body or fiber glass?
1 - 11 of 11 Posts
