Look at your work order from the shop. It will often have info on any sort or warranty on it. If it doesn’t, call them and ask about one before saying anything about the actual problem.
Appreciate the recommendation.Look at your work order from the shop. It will often have info on any sort or warranty on it. If it doesn’t, call them and ask about one before saying anything about the actual problem.
Shop inspected the hose, only the outer part of it was torn, the wire webbing inside the tubing was still intact (not cut all the way); Push/Bent the A/C line a bit and wrapped it.Does not look like ac line needs replaced
Could loosen fitting and reposition in less time then it took to take the photos and write the post
Could also add a piece of inner-tube between to insure no further contact
or could go on in this direction
