The inside windshield moulding is falling down on my 06 wrangler. The one corner doesn't even match up and won't reach. Any thoughts? Do I need to replace the windshield and moulding? Or can I get it resealed?
Is it plastic or rubber?its not leaking It looks like just a decorative moulding
The only thing I know of around the windshield that is rubber is the mounting gasket. So far as I know you need that. It is not decorative.rubber
I know exactly what your talking about. Mine is falling off as well. Top drivers side of the windshield. On hot summer days especially I'll come out and half that damn rubber seal or whatever it is is hanging down touching the dash. I have a 05. I was thinking on using a adhesive like pl premium or something like that and trying to glue it back up and there. Mine doesn't leak at all either. Just a painrubber
Yep , It's just decorative. I had my windshield replaced last year. they had to take that out a it fell apart in the process. They windshield guy said that that was common,and that it was decorative, and if I wanted it replaced he would order one. i still haven't replaced it yet.^the windshield glass is urethane caulked to the steel frame from the outside. The inside rubber molding is just decorative, covering the inside exposed edge of said steel frame. It doesn't provide any kind of seal. Try some 3M super weather strip adhesive to glue it back in place. Be careful with it as it gets messy.
Thanks everybody. I will get the 3M sealant and use that thanks for the information
