Hey anyone, not sure if this is the right place for this question but it sorta relates to wheels and tires so here goes. I have a stock 2010 Wrangler unlimited and I (of course) want to go a little bigger with the tires. I'm thinking I'll stay with stock rims plasti dipped but I've been considering a Leveling kit just to even out the stance and allow for a bit taller tire. Can a leveling kit be installed by just one person and with common tools? Or there any specialized tools and should I take it to a mechanic? Thanks for any tips!:confused:
Should be able too. I replaced the 3/4 inch factory spacers in my TJ by myself. It took about 4 hours and a lot of cussing but I did it. My big limitation was jack stands. Not high enough and so I had to compress the springs with ratchet tie downs. Spend $50 and buy bigger jack stands or rent a spring compressor (or just buy one). Other than that, it was just ratchets and wrenches, etc.
I've heard horror stories about how the springs broke loose and injured the guy breaking his arm. is that a danger or would lifting the jeep high enough take care of the need to compress the springs? Thanks for the info btw
