1 - 1 of 1 Posts
Vendor
The new Lumen grille with white DRL/amber turn signal LED lights is an exterior upgrade that will turn your stock JK Wrangler into a show-worthy off-road machine. Thanks to the tough impact-resistant ABS plastic and built-in LED lights, it will make your Jeep stand out from the crowd no matter if it's day or night.
We've prepared a detailed step-by-step video instruction to guide you through the installation process.
Lumen® - 1-Pc Textured Dark Charcoal Main Grille with White DRL/Amber Turn Signal LED Lights at CARiD.com
Specifications:
  • Installation type: replacement
  • Finish: textured dark charcoal
  • Material: ABS plastic
  • Number of pieces: 1-pc
  • Lights: white DRL/amber turn signal LED lights
Features:
  • Designed to fit the Jeep Wrangler
  • Adds style along with great protection
  • White DRL/amber turn signal LED lights for maximum visibility and safety
  • Made from durable automotive-grade ABS material
  • OEM-style dark charcoal textured finish for sleek looks
  • Quick and simple installation — no cutting required
  • Not compatible with forward-facing cameras
Includes:
  • 1-Pc main grille
  • Wiring harness
  • 6 Pcs screws
  • 2 Pcs plastic brackets
Light up your path with a new Main Grille with White DRL/Amber Turn Signal LED Lights by Lumen!​
1 - 1 of 1 Posts
