1 - 1 of 1 Posts
Had Speed World in Baldwin, L.I., N.Y. install it for $80. As
Moroso shows on their YouTube install video it is a custom
set up for the Wrangler that looks good. Only thing I would
recommend is that when they position the canister in the
holder, make sure the 'capped' drain plug is facing on an angle
toward the driver's side headlight. This allows the drain pipe
to hover over a small open area that allows you to easily place
a small receptacle whenever you want to drain the canister.
Moroso does fit the unit with an 'open-close' switch which prevents
any oil build-up from dripping out when you remove the rubber
drain plug 'cap'.
1 - 1 of 1 Posts
