So I'm running into a problem when trying to install my 3rd break lights on my 2002 TJ. I have all of the hardwear to do it but on the inside of the trunk door, the box that you wire them through contains an adaptor that connects to positive and negative that the previous owner must've took/lost. I need help finding this part!!
It shouldn't be an issue to simply twist, solder, and cover those connections. They won't be quick disconnect but how often do you really plan to remove the tailgate?
4362012 TERMINAL, C.H.M.S.L. Contact Button
this should be getting from Chrysler.com.
when you pull the buttons out the wires fall back inside:atomic:
