This is a guide to installing an aftermarket radio and 4 speakers for the TJ. Install was done on my 2003.
I am wanting to contribute more to this forum and after updating my sound system decided to make a write up on installing an aftermarket radio and 4 speakers.
Time to change this
To this (I know bad photo, was taken by my phone)
My suggestion to get all the stuff you need is at crutchfield.com When you buy anything there, they give you all the adapters you need to install it.
I will start with a list of items required to do the install.
In Dash Radio
1 Chrysler dash radio mount kit, as the OEM radio slot is larger than standard DIN radios. Can pick this up for 15-30 at auto stores and walmart.
1 Chysler radio wiring harness. 10 bucks at walmart. Why even bother with the cumbersome splicing in the car. I don't want to think of this as optional. If you want cut the old plug off and splice the new one on find your Jeep wiring diagram here.
1 Chysler antenna cable adapter.
Your choice of a single DIN aftermarket radio.
Front Speakers
1 Pair of speaker adapter brackets. The OEM speakers don't fit into any standard speaker size or mounting holes, so brackets are required if you don't plan to fab the mounts.
1 Pair of 4" x 6" speakers
Optional - Speaker wire adapters. If you don't want to cut wires.
Roll bar speakers
1 Pair of 5 1/4" speakers fit perfectly in the existing holes
I ordered a radio, 4x6 speakers, and 5 1/4" speakers all from Crutchfield and they included all the required adapters and wires. Also got free shipping for spending over $200
Here is a pic of everything you should have.
I suggest you make all preparations now before removing parts of your vehicle to make the actual install much smoother. Take out your wiring diagrams for the radio harness for your aftermarket radio and the Chrysler radio harness. Normally all aftermarket radio wires follow the same color codes but don't take that risk and compare the two wiring diagram. For some reason Chrysler has two wires for constant power and two for ground, other than that everything lined up.
Everyone has there own favorite way of splicing wires, I used plain old standard crimps.I also decided to shorten the wires as I didn't plan to make mistakes and it won't get as tangled up.
Next, remove the metal sleeve that's on the radio, and attach it to the dash mount. Then pry up the tabs to keep it in place.
Now attach the antenna adapter to the back of your radio, and attach the speaker wire adapters to your new speakers.
Attach the speaker adapter brackets onto your 4x6 speakers using the included screws and nuts. I had to widen some of the holes on the bracket using a dremel to make it fit on my speakers.
Prepping is all done, now to tear out your old radio and speakers.
Time to change this
In Dash Radio
Front Speakers
Roll bar speakers
