1 - 10 of 10 Posts
Hi all, I have a 2015 Sahara with 18x7.5 stock OEM wheels. This weekend I'm purchasing a set of 18" OEM 2014 Jeep Wrangler Altitude Edition Black Wheels (with the same tires I have now and TPMS sensors inside). These should "bolt on" with no issues correct? I want to make sure I won't have any TPMS issues, offset or rubbing issues, etc. Any info would be greatly appreciated. Thanks!
They'll bolt on. "IF" you throw a code (light) after you drive a distance over a certain speed it should go off after the computer recognizes the new tpms signal.
Cool, thanks!
One time I had to stop by my local Jack Williams tire and he took a magic wand over each tire and said, "You're good" took about 1 minute so that is your worst case scenario in the off chance your computer is crabby and doesn't take the call from the TPMS's.
ExtremeTerrain.com Sponsoring Vendor
I just double checked and the '14 and '15 JKs use the same TPMS frequency of 433mhz so they'll sync right up! Good luck and enjoy your new wheels!
-Ryan
Discussion Starter #6
-Ryan
SWEET! Thanks Ryan & RubiconSS! Can't wait to put on my new wheels!
Discussion Starter #7
Hi all, I purchased the wheels and the TPMS sensors aren't registering? Any idea how long they take to register? I've driven about 20-30 miles on them so far. They look sweet though!
Discussion Starter #8
Hi all, I purchased the wheels and the TPMS sensors aren't registering? Any idea how long they take to register? I've driven about 20-30 miles on them so far. They look sweet though![/QUOTE
Here's a picture of them installed.
Had the same problem with my new wheels, tires and TPM sensors. Tried everything and then everything again. Brought it to the dealer and they recalibrated them, so they said and now I have them working perfectly.
Discussion Starter #10
Cool, thanks for the info Mazz!
1 - 10 of 10 Posts
