I have a 1989 Wrangler Sahara. It is the carbureted model, I believe it is the 4.2L 6CYL. To make a long story short, I'm missing the entire air cleaner assembly. Theres just a bare carburetor sitting there. I'm having a really hard time finding a new or used setup. I'm not into jeeps all like that so I'm not sure where to find parts. I've tried searching google and eBay with no luck.
Aka Vaultzz
I had this problem back when I needed inspection. Nobody sells the stock air box. Your best bet is to look around junkyards. I just took a $10 air filter from autozone that came with a base and attached that over the carb, then drilled holes for the emission tubes
