Quick back story, owned my jeep for almost 10 years now. Has had a 2.5 in it for 98% of its life. Going on about 6 months of my 4.0 swap and I have pretty much 1 last problem that is getting the better of me. I’ll try to make this reading as easy as possible.
When I start the jeep it sometimes has a long hard start with a hard knocking/starter kickback noise and will either start and idle/run very bad or not start at all. I can then turn off the key, try to start it again and get the same results or it starts up like it’s brand new and runs fine.
Every sensor on it is new, starter, alternator, dostributor, coil, plugs, etc. all new due to the swap process. Used ECU with the new capacitors and new harness. Fuel pressure reads high if it’s running good or running bad. I’ve taken the fuel line off the return side of the rail and ran a hose into a gas can and my pressure drops to somewhat normal with a working regulator. Regulator has no change in pressure when the return line is hooked up. Bad start problem still occurs in either scenario.
I’m at such a loss I really have no clue what to look for next. I might try to check the fuel pump this weekend but it was working fine before the swap. Any ideas or any one have any similar problems? It’s my daily, and still gets me around but I’d like to fix the issue.
