I am currently running about 2.5" of lift with OME springs (with 1" BL) and all stock control arms and track bars other than an OME rear track bar relocation bracket. I just acquired an Iron Rock Adjustable Rear Track Bar because my rear axle is a little off-center even with the track bar relocation bracket. Should I remove the relocation bracket to best utilize the new adjustable rear track bar? My concern with this is a steeper track bar angle which will cause more lateral axle movement through the rear suspension travel. However, I like the idea of removing the relocation bracket to reduce the leverage put on the factory axle-end track bar bracketry. Give up all that wisdom....
The rear track bar should be level at ride height. Leave the bracket in if keeps the track bar level.
make sure you check full bump and beware of track bar vs frame clearance issues.
