Hey guys im new to jeeps and this so take it easy on me
I have a 91 yj. It's new to me so I don't no much about it past mechanic work but it has 150,000 50,000 pulled behind a camper. First of all the clutch is letting out real late now. On day I looked at the fluid and it was really low so toped it off and my buddy said I need to bleed it. Here is the problem the bleeding bolt is broken don't ask me how. So what do I do?( drill it out??? Its in a bad spot tho). Then now when I take off slow( only happens some times) I get a bad jerk. What does that mean???? What do I do?.???
Help please !!!!!!!
If the fluid was low enough to get air into the system then it needs to be bled. You will need to take the broken bleeder out with a drill and easy out. You might have to remove the master to do it.
