Hi all..getting my new Jeep today and have a basic question. Is my Jeep lifted or just new shocks?
When I asked the dealer he said no the Jeep was not lifted but when I looked underneath I noticed it had TeraFlex 9550 w/ Green Springs.
Is there a standard measurement from the top of tire to bottom fender?
Thanks
Thanks
Based on the pictures it looks like a 2.5" spring lift. Most likely Teraflex given the shocks. Check out the other suspension components to see what else has been changed.
Look for bump stop blocks on the bottom rear pads of the rear axle. The picture appears to show bump stop extension on your front bumpstops. I just installed a teraflex 2.5" 4 door lift on my neighbor's unlimited.
Look for these parts:
https://teraflex.com/shop_items/528ffa7fead962f416e72d47
The rear axle trackbar relocation bracket, bump stops, shocks, and swaybar end link changes are the most obvious.
Brand new, or new to you?
If it's brand new check the window sticker, I doubt the dealership is going to give away a lift kit.
on edit: From the fender/tire gap it looks lifted to me.
I do not see the standard TF bump stops in the front. Does it have a rear track bar bracket on either frame or axle side? My initial guess is TF performance leveling kit, but it doesn't look all that level.
Picture of rear axle?
