So I rigged up a pulley system in the garage and pulled my JKU hardtop off for the first time. I noticed that on the drivers side of the top there is a small nipple sticking down (above where the door pillar would be when the top is on)but its not on the passenger side. The nipple is actually a small screw hanging down wrapped in a rubber outer. Is my top defective or is this normal?
I think it is just an alingment pin. I will look at mine when I get off work in the morning.
I am pretty sure you are missing one. It is for location of the hardtop. Look at the cage bar right above the door there will be a thicker clear tape like material over a hole about the same size as the black plastic pin. On my 2013 JKUR they are white pins?
My 13 is like yours, only 1 pin on the drivers side. Hopefully it's normal.
well mine makes 3 so I think it is normal
Retired Mod
Normal...
