1 - 17 of 17 Posts
Thinking about buying a this lift from superlift
:pc-ouch:
1.5" Jeep Suspension Lift Kit - 1987-1996 YJ - K722 | Superlift
or this one from skyjacker :jawdrop:
Skyjacker 2.5" Sport Suspension Lift Kit with Hydro Shocks for 87-95 Jeep® Wrangler YJ - Quadratec
Can anyone give me a hint or review for a good quality daily driver from these two?
has someone used them?
Not looking for a stiff ride.
my setup is 4 cyl wrangler 95, 1"body lift, 31" tires. occasional offroad.
Please help, don't want to make a decision without consulting fellow jeepers.
:drinks:
Discussion Starter · #4 · (Edited)
This is my ride, don't know if a 1.5 lift will lower ir or lift it... it seems like i am in the middle, but boy am i looking for a decent ride, you see it kind of backlashes, would superlift do the trick? for $521, BDS is $777, OME $1041 RE: $ 800, Tought contry $500, SKYJACKER SPORT $581.
It all comes to spring rate i guess... what's your experience? my city has some uneven pavement roads, and pot holes all over, you fall and it's like riding a skateboard with no suspension. looking for some flex, and suspension work. I mean i did torque the bolts and seemed to help but now it backlashes a little bit for my taste.
https://drive.google.com/file/d/0B6jxIaaK6Je8R2ExdDRvZ0pINzA/view?usp=sharing
hi chestercospin, i notice you have a funny shackle at the back, does it help?
mine is like at 90 degrees to the chassis, a friend of mine tells me that it's not good.
How would you describe the superlift ride feel?
is the height close to stock?
I have a 4" skyjacker lift (shocks/leaf springs) and I am happy. I wouldnt say it's smooth but I'm not sure it's possible to achieve that with leaf springs on both axles. But I'm happy with skyjacker although I have much less experience than most here who may have owned vehicles with different brands and setups
Sent from my LG-D959 using Tapatalk
I have the 1.5" superlift kit, 1" bl and 3/8" shackles. Love the ride and it fits 31s great.
To me you look like your about where I am, 2.5" spring and 3/4" to 1" shackles, you may just need better Shocks, this said, I don't know what shocks you have, but the right ones make a big change of ride, some lift kits have shocks that you can jump hills and not hit bottom when you land, but ride like zhit, good shocks!
Start with some heavy duty boomerang shackles, preferably greasable and remove your track bars. If its still bad then try shocks.
I did a lot of research before removing my track bars. After almost a year I decided to try it but I only did it for offroading purposes. I had read a lot about the ride being better but it was inconsistent and I thought it must be the placebo effect. It definitely rides a lot better. My son, who hardly noticed the difference when I painted it, noticed how much less "backlash" there was. It does handle a bit different also but well worth the trade off.
i have tried procomp 3000 for a 2" lift...and i thought the ride was stiff...so i tried autozone shocks because i didnt wat to spend much trying ... right now the ride is stiff but kind of woobly because i torqued to 50 lb*ft, I am thinking to switch to the procomp now that i torqued the bolts to see what happens but they are for a 2" lift... i wonder if they would work. i dont think i have a 2" lift
yes i removed the trackbars already and yes it does make a difference, but still want to get a better ride, my back hurts, a lot of baklash, but yes i recomend removing the trackbars also, torque and tire pressure, now i wonder about oil shocks vs nitro shocks, spring rates and old bushings.
That's why i am wondering if to buy the superlift or the skyjacker kit which are around 550 dlls
:pc-ouch:
:drinks:
Looks like you're already lifted. Best ride and flex with always come from a flat leaf spring. The larger the lift, the more arc, the firmer the spring (assuming leaf width, thickness, and materials are none variables).
They are M.O.R.E. 3/8" boomerang shackles. Can't comment on angle.
The ride is good, a tad more bouncy than stock but not much. Its gotten better since installing last year. Leafs have settled. Its a YJ. Its a rough ride compared to a car. I tell my wife its my version of a core exercise.
You might want to try new shocks before replacing the leaf springs.
I gained just under 2" of lift over the stock springs they replaced, but my stock springs were shagging, so suspect I gained a true 1.5" over the factory height. hope this helps
Shackle shape does not affect angle of shackle. eyelet to eyelet length on leaf spring and mounting location does.
1 - 17 of 17 Posts
