^^^^ThisHow much is making it to the ground? If she's just seeping I wouldn't worry too much about it. And what does the backside of your motor look like? Could be valve cover.
I have not tried this yet. Do you know the torque spec for the pan bolts. It's an 03 with only 61,000 miles on it :drinks:Did you try re-tightening the pan bolts? I did on mine and the leak went away. How many miles?
It's not making it to the ground at all. I need to get my ass out to the garage and check the valve cover but I don't think its contributing to the oil pan gasket. I could be wrong.How much is making it to the ground? If she's just seeping I wouldn't worry too much about it. And what does the backside of your motor look like? Could be valve cover.
Dont have any clue as to the torque specs.. I used a 3/8" ratchet with a short handle and extension ... just tightened as much as i could.
