My 89 yj 4.2L has never really put out substantial amounts of heat. Didn't know if it just wasn't built for much heat or some other reason
some other reason. it should run you out.
Does your cooling system seem healthy? Sometimes if you've been using a weak antifreeze mix (it also contains essential lubricants and rust prevention agents) rust particles can gum up the heater core.
I'd imagine stop-leak preventatives and similar agents could also reduce the efficiency of your heater.
Hope you find a solution - extreme cold right around the corner!
I might try flushing the heater core on Sunday. But coolant is fine and radiator was replaced befor it was parked prior to my purchase of the vehicle
