The wrangler starts fine but I am having an issue. It idles high and the speedometer shows 20 mph when in park. When I put in Drive, engine speed will lower and will take off fairly quickly without using acceleration.
If I adjusted the idle to where it should be when in park, it will stall when switched to drive.
I did install a brand new carb.
Its an automatic 6 cyl.
Any suggestions?
In you have not, frist with a cold engine adjust the choke, then start the engine and let it run and adjust the timing to 9degs. BTDC then when at full temp adjust the Carb. useing a vaccum gague. then should get you to a point that you can Start Fine tuning it.
