Hi,
I have some issues with my Uconnect-System.
I'm from Germany. I have a Jeep Wrangler Unlimited Sahara MY 2015.
My Unconnect-system does not work in some ways. The most annoying issue is that I can not play music over USB (via Ipod or Iphone) or Bluetooth anymore. A connection is not possible. Other issues are:
>Voice control does not work.
>No voice from the navigation-system.
Radio-function is fine.
According to the Jeep dealer in Germany I have to replace the whole system/unit, which will cost about USD 750.
I'm not sure, if this is only a software issue. However, according to the Jeep dealer no software is available to reinstall the system. Also no software upgrade for the system is available.
Does anybody experienced the same issues and has a solution?
Many thanks
Ralf
First, have you checked that you have the latest firmware? Go to this website and enter your VIN#.
https://www.driveuconnect.com/support/software-update.html
And then pulled from here http://www.wranglerforum.com/f274/uconnect-730n-soft-reset-technique-1398241.html for a soft reset of the 730N.
1). On the steering wheel, hold down both the button with the telephone icon as well as the button with the voice recognition icon for 30 seconds (at the 32nd mark there will not be any beep or indicator to let you know).
2). Release the buttons. Turn the ignition to the off position. Open the driver side door and leave it open for 30 seconds.
3). That's it. Close the door turn the ignition back on.
4). (For the issue I was having I also had to delete my device pairing in the settings screen of Uconnect AND "forget" the Bluetooth device connection in the settings screen of my iPhone.)
