Why do you need a delete pulley? If you want to delete your A/C, just leave the compressor in, it does not hurt anything.
Reactions: Got it at last
It's worth leaving it in as a pulley as the factory part that would replace the compressor is almost non existent anymore and $150.00 if you can find one. I made my own as a project but still ended up into it for about $60, only got rid of mine because I hated fighting to get the #1 plug in and out. Down the road you could turn it into an onboard air setup if you wish, Just disconnect the power to the clutch so it doesn't accidentally kick in on you and you have a free pulley.
Good luck
Thanks gents
I just thought it would clean up the bay, since I’ve pulled out all the old vacuum lines
And computer crap. That’s all
You can Still pick up a couple caps and pull your lines, If you plan on using your compressor I again I wouldn't leave the system open. Some Kits were fitted with valves you could close off right at the compressor, not needing the caps
