The only place I can get a safe grab with my Hi-Lift is on my bumper or rock sliders. I would have to lift the body pretty high to get a wheel off the ground so it could be changed. And I doubt if I could do it without a spring falling out if I was on the trail with my sway bars disconnected....... a Hi-Lift should only be considered as a last resort for tire changing duties.
Re-read exactly what I said.why would you consider it last resort? Ive used mine too put my spring back in. worked great and fast
Yupagreed.... any of yall ever seen a hi-lift kick out from under somethin?
get a good aftermarket bottle jack /// most aftermarket bottle jacks have an ajustable head that you can hieghten up to the axle before you jackok i just bought a wrangler. it has no jack what so ever. the jeep has a 9" suspension lift and a 1" body lift with 37" tires. so is someone gonna tell me to not use a Hi Jack as my only jack? is there something safer to change a tire with the set up i listed? yes i know hi jacks are great and all, they do this that and the other, but for me buying ONE jack and ONE jack only to use where ever i may need it, trail, street, where ever... what would you recommend ?
