1 - 20 of 28 Posts
Any tips for using Jack Stands with a lifted Jeep. The tallest lift from most decent jack stands is only 24". The frame on my Jeep is already 18" off the deck, and I think that there will probably be more than 6" of travel from the suspension when I jack the Jeep up. Any suggestions for how to get some extra height from the Jack Stands, or do you all think that 24" will be enough.
Ian
What are you looking to do?
If I'm rotating tires or doing brakes or whatnot, I just put the jack stand on the axle tube. That way I'm not having to account for suspension droop.
If you're looking to do suspension work where you need the axle to droop, you may be in a pickle.
Adjusting the parking brake. So I guess I could use the axle tube. If I do this though, then how do I Jack her up? If I raise up one side, I'll have to over raise it a lot with suspension droop before lowering it back down a bunch again. The only Jack I have is my Hi-Lift.
Ian
They make a wheel lift adapter for the hi lift jack. Maybe you could rig up something like that if you have a ratchet strap or something.
*disclaimer* may result in death
what jack are you using? i have 35s and my stock jack under the tube is enough to get the tire off the ground and a stand under the axle .
If you are using a hi-lift, just strap the axle tube to the frame beforehand.
You can easily make a 3" or higher - platform for your jackstands. Just screw together some scrap wood.
Mark
Sent from my SM-G935V using Tapatalk
If you use a floor jack and are on stable ground, place your jack under the pumkin and have the jack stand ready. You only need to lift like 1/2" from the ground to free the wheel. No big fall can happen. Or just lift enough to have the lowest position of your jack stand. And drop on jack stand right away. If you are on dirt, 3/4" strip of ply wood under floor jack and also under jack stand.
Discussion Starter #9
I don't have a stock jack, just the hi-lift.
Discussion Starter #10
I'm tempted to buy a floor jack, just so I can do that. Hard to hide from the wife though....
Buy The Floor Jack
Just buy the floor jack. It is going to cost $50 to $100 on the low end vs. possible death by crushing. It will make other tasks you have to do in the future much easier.
Buy a $20 two ton bottle Jack for jacking under the axle.
I got a 3 ton floor jack from Harbor Freight for about $100 and it is great.
Makes tire rotations and brake work a breeze. I bought it to do my lift, but I use it for everything now.
look at a RV scissor jack. plenty of lift.
get a floor jack. I have used my floor jack so many times over the years that it has to be one of the most used tools I have.
Pick up whatever HF floor jack has the tallest reach and while you are in the store, pick up a set of 4 ton jack stands and wheel chucks....for less than $200, the setup works great.
Discussion Starter #17
My nearest HF is a hike.
Discussion Starter #19
many places sell floor jacks besides HF check your local Craigslist.
1 - 20 of 28 Posts
