Make sure you have the bearings pre-greased and ready to go.
From the bottom;
1. Install in bearing, tapper facing up into the hub on the carrier.
2. Tap the seal into the hub. This will capture the bearing loosely.
Set carrier on the spindle, seating the lower bearing previously installed on the spindle.
3. Install second bearing from the top, tapper facing down into the hub. Wiggle the carrier until the bearing seats.
4. Install the large washer on the spindle, on top of the bearing.
5. Thread on the large nut. Tighten based on preference on how tight you want the swing.
6. Thread on the bomb-proof cap.
7. Go wheeling!
