Can't seem to get my back door open. I sprayed WD40 on all the hinges and have yanked it as hard as I can. It's probably a simple fix, but I thought I'd ask before I go messing around with it. Anyone else had experience with this?
Is it unlocked? Assuming the lock switch is in the unlock position, you may have a control rod that popped off. You cannot remove the door panel with the door closed, but you can take the door off its hinges and remove it, and then remove the door panel.
