The noise is independent of steering wheel position? So you are ruling out steering linkage? The noise is not present when the Jeep isn't moving and you jerk or cycle the steering wheel back and forth? I've just seen alot of noises come from control arms and track bar mounting points so I almost always think those spots first.
I don't think a "spike" in forward or reverse throttle would uncover a ujoint noise. If you suspect a ujoint, first what condition are they in? Have you changed them, are they greasable? You can sometimes tell on an OE ujoint when they are wearing out because of the red rust dust that is present around the caps. You'll often feel a resistance in the steering wheel when you make sharp turns. I suppose it is possible that maybe you cracked a needle bearing inside of an otherwise good ujoint and it is creating some noise, but I'd kind of be surprised.
Do you have a engine mount lift? Have you ever moved the fan shroud? If so, any contact between the fan blade and the shroud?
Have you had somebody outside the vehicle try to isolate where the noise is coming from? Maybe in an empty parking lot with your hood up and a person paying attention to things as you try to recreate the problem from a dead stop?
A rock in the tire you'd hear above any certain speed and it would be consistent with speed (not rpm), but it would exist under normal load, which you say it doesn't.
