Hello everyone, this is my second post and after about an hour of looking for what I need, I decided to make a quick post. Apparently my Jeep is missing some cushion in my hood so I attached some pictures, also I was wondering what the missing screws for my grill area are. Thanks!
The 'cushion' is just insulation that helps it sound quieter maybe protect heat a bit on the hood. This is not included on my Sport, but on my wife's Sahara so I think it's an option.
The downside is it's tougher to clean the inside of your hood after a high water fording where the acc belts will sling it to the hood.
Don't need it - only put it on if you want to.
Unsure of the hood holes!
Those two bolts are just to hold that body piece in place. You should be able to order them from a Jeep dealer, or take one from the other side to Ace Hardware and find a close match.
FWIW, I took my hood insulation off. It gets nasty after a while, and I see no reason to keep it there.
Reactions: Haust
Grooving With A Pict
https://www.tascaparts.com/oem-parts/mopar-cowl-grille-screw-6509190aa?origin=pla&gclid=CjwKCAjwnrjrBRAMEiwAXsCc42Gyq_aiYHUp9tdknGmkjWnTjYXCTeV3_kh9914GckSYqCydG3XY1BoCCqcQAvD_BwE
Cowl Grill screws :)
Or you can opt for some pricey stainless steel ones.
https://www.route66mods.com/product/jeep-jk-cowl-screws-8-pc-stainless-steel-set/
The hood silencer/insulation piece is part# 55361338AO. For $120 bucks I really don't feel like it adds any value whatsoever to the vehicle unless you're overly concerned with minute engine noise.
