Rating: 9.5/10
Pros:
-Stiff Shocks. Which lead to a nice smooth ride.
-High quality material
-Look great
-Perform great on road and off.
Cons:
-Stiff shocks. Some prefer the softer shocks over the stiff.
-The upper shock mount has to be held with either a 1/4" wrench (which i did not know) or vice grips to the piston. This is a con because the upper shock mount area is a very tight area, and to have to fit 2 wrenches, is rather difficult.
5160- (have not had enough time to fully test)
Rating: 9.9/10
Pros:
-A little bit softer (but not by much) than the 5100s. Which give a VERY nice on road smoothness.
-Look awesome!
-Reservoir lets shock flow smoothly.
-Upper front shock mounts only need 1 wrench to tighten.
Cons:
-Wish the reservoir to shock cable was an inch longer. So the reservoirs could mount to the cross member more easily (most common mounting place on JKs)
Not sure if its my luck or its the 5160s.
I had to warranty 2 of the shocks because of leaks... :confused::banghead:
I'm probably going to be changing them out for Fox Reservoir soon.
that typically happens if a Jeep isnt bump stopped correctly. if the shock is overextended or overcompressed.
Does the remote res cannister not fit mounted to the chassis. I have just made a 2" pipe section to bolt under te chassis cross member to mount these to, but have not test fitted them yet.
Hmmm...... the front upper mounts on my Bil Steins 5100s use an allen wrench.
i have my rears attached to the cross member.
i will be moving parts around looking for different places for the resis.
and yea, there is an allen spot, but i cant fit an allen in there on mine.
