Jeep JK electrical issue?!
742 4
Whats up everyone.This issue happened a few months ago and never happened again until this morning.While im just idling in a parking lot out of nowhere i hear the famous instrument panel beep and ALL of the lights come on and my wipers come one then it stops after a second or so.Maybe 15 seconds later it does it again.Only did this a few times and hasnt done it since now 30 mins later.What are some things that cause this?! Thanks guys
2010 Jeep Wrangler Sahara
35,554 miles
It could be as simple as loose battery cable connections or more serious like a defective Totally Integrated Power Module. The TIPM could also just have a bad connection to the system. I would start with those connections if my 10 had symptoms like you described.
Loose battery cable was my culprit. Negative cable never got tightened after a remote start install.
Out of curiosity, did you get a resolution to this? If so, what exactly was the problem. Am having a similar issue with only a few panel lights and no wipers. Will check battery connection first thing in the morning my time.
Thanks!
Ditto... I only have this issue on the trail when twisted up ...
engine still runs fine but the electrical resets.. no wipers though..
agree somewhere a connection is loose but finding it is the issue.. :bop:
