I've been experimenting with different phone mounts for my 2014 jk. I have a iPhone 13 pro max. It's a pretty heavy phone. Putting a metal plate at the bottom of the case and using a magnetic mount wasn't ideal. Too much shaking and it would slide. I also didn't want the phone to block the view out the windshield. Here's what i finally landed on using magsafe. I also modified the mag mount and removed the non-magsafe magnets. There are 4 Phillips head screws under the adhesive. You don't have to remove the adhesive to get to them. Just cut a small slit to access. When mounting the mount to the bracket i clamped it in place for 48 hours before using it to allow the adhesive time to cure. I'm using a Incipio duo magsafe case with the magnets built into the case. Here are the links to the magsafe mount and bracket. I didn't use the holder that came with the bracket.
https://a.co/3tyQ6IC
https://a.co/6Zzs7Ii
Composite material Gadget Auto part Rectangle Electric blue
I use Mob Armor. Works awesome. I have never had my phone shake loose or even move a bit while using it.
