1 - 9 of 9 Posts
So the last couple times I've had to sit in heavy traffic my jeep starts to drive funny. It will pull hard to the right and the brake pedal will have a strange feel to it. A few times I've smelled what maybe brakes. I'll notice that if I'm on a slight incline the jeep wont roll if I let off the brakes.
I just recently got Mickey Thompson Classic III with 33inch tires and the jeep aligned. From what I can tell the steering wheel is aligned and drives straight till I get stuck in traffic. I don't do a lot of heavy braking but I do live in hot and humid Florida. If I pull off for a bit and grab a bite and let it cool down it then drives perfectly fine. I also just recently changed my brakes but I do have a bad speed sensor that is throwing the ESC light and get the light squeeze on the right side when I start up. I don't do any wheeling right now and am strictly mall crawling. (sad I know...)
Immediate thought is that you have a stuck caliper that doesn't release after sitting in traffic for a bit. This makes sense, especially if you smell what appears to be your brakes.
Also - if you have Hill Assist on, it will not roll backwards as it engages the rear brakes on a hill.
Hill assist is not on as I have a bad speed sensor, so the ESC light is on but it's been on way longer than i've had this issue.
caliper... had the same issue with the wife commander, got a re-maned caliper and flushed the brake lines...all good now.
you can try and bleed the brake lines to see if that helps and also spend an afternoon and clean/ grease the brake pistons. Tones of youtube vids on how to do this!
My old JK did the same thing one night. I pulled over and looked at the front left tire(was pulling to left) and the brake disc was glowing red hot! Stuck caliper, which released once it cooled down. I had the caliper replaced.
Few months later, the right brake did the same thing.
1 - 9 of 9 Posts
