1 - 11 of 11 Posts
Alright, my 2017 Rubicon is showing it's first sign of an issue. After getting back from a wheeling trip which included multiple water crossings and winch usage, she drove the whole way home just fine.
The next day after driving around town, I come up to a light and as I'm coming to a stop and push in the clutch, she revs up and down from ~1k-2+k multiple times. It doesn't happen every time, but it happens almost every time if I turn the vents on, even just low. It'll idle noticeably higher with the vents on, but the moment I turn them off it comes back down.
I think this may have been a slow developing issue, because thinking back there were periods where I would notice sluggish then sudden acceleration patterns in the past.
This doesn't seem like a common issue, since I can't seem to find much on it.
But so far, most articles point to possible vacuum line leak. Sound right? Or where should I start looking?
I appreciate any insight.
It sounds like a throttle pedal failing. It is only a sensor that tells the computer how far you are pushing the pedal. It is all electronic.
It could be a vacuum leak, but they way you describe sluggish pedal response in the past points to an issue with the throttle pedal, not a vacuum leak.
Of course I could be wrong. But ours had a failure of the throttle pedal.
Where would I find that? And any way to test it?
It is down by your foot. You push on it with your foot to go. I am sure there are tests you can run. Or you can replace it for just over $100. It is an easy job you can do yourself if you buy the part.
One thing you might could consider, if it is in the throttle, is getting and iDrive. Might not fix your issue, or it might, either way its a good upgrade regardless so its not something you would regret getting
When ours had a throttle pedal failure the throttle widget made it worse. I don't know how, but it did. I would fix the issue first. If you want a widget after that, go for it. But my experience says don't install a throttle widget when you have a possible throttle issue.
Interesting and good advice. My thought was the iDrive would overide the signal and "fix it" when you set it but experience always wins out!
The iDrive looks interesting and definitely something I would try out. But I'd rather not add a new variable to the issue. Solve the issue then maybe try it out down the road.
On the hunt for a throttle testing method... Start ruling some things out.
I'm guessing it's one of the sensors that measures air flow. I doubt it's the throttle. You would see that using any scan tool looking at the throttle position %.
1 - 11 of 11 Posts
