Wrangler Forum banner
1 - 17 of 17 Posts
Hey All...
My 2007 Wrangler X literally sprays fuel back out when I'm gassing up. It only does this when the tank is fuel. And when I say full I mean it is FULL! It pumps completely normal and then -- whammo-- the nozzle clicks off and gas simultaneously shoots back at me without warning. Usually it's just a little bit but sometimes it's a lot. I have to rinse and dry the entire back quarter panel of my Jeep.
Because of the angle of my tank most gas pumps turn themselves off unless I hold the nozzle up continuously. What I've started doing is holding the pump nozzle in tightly with both hands to give it a really tight seal; that usually minimizes the amount of spray. Today that created some sort of massive reverse vacuum because as soon as the pump clicked off, gas -- and I mean a lot of gas -- shot sprayed out. It covered me and my ride this time.
Has anyone else ever encountered this?
Thanks...
Tommy Wo
Hey All...
Thanks...
Tommy Wo
You're covered under this TSB:
SERVICE BULLETIN NUMBER: 14-001-13
GROUP: Fuel System
DATE: January 30, 2013
SUBJECT:
Fuel Spit Back During Refueling (X47 Lifetime Warranty Extension)
OVERVIEW:
This bulletin involves replacing the fuel tube at the fuel tank. This new fuel tube has a check valve.
MODELS:
2007 - 2008 (JK) Wrangler
NOTE: This Extended Warranty Bulletin applies to vehicles equipped with a 3.8L engine (sales code EGT) built before March 1, 2007 (MDH 0301XX) and after March 31, 2008 (MDH 0331XX).
SYMPTOM/CONDITION:
Some customers may experience a fuel spit back condition during a refueling event.
DIAGNOSIS:
If the customer experiences the symptom/condition, proceed to the repair procedure.
NOTE: Vehicles included in this Service Bulletin have a lifetime coverage warranty for this repair.
__________________
Andrea
Jeep Social Care Specialist
This is funny because I was filling up before wheeling in NJ (they pump the gas) and the woman told me I have a polite Jeep. I looked at her confused, and she told me that unlike many Jeeps, mine didn't spit gas at her. I thought she was kinda nuts until I read this thread!
Thanks I guess im gonna check into this...Mine is 2008 Sahara and it does it all the time.
I just had the tank replaced for the same issue in my wife's 08 Liberty. It is a known well documented issue, and Jeep is offering a lifetime warranty for the problem.
Skip the dealership, go to Jeep.com and chat with them, they'll give you the name of the campaign and all the info. Then go to the dealer. I had all the info, called the dealership and asked if my problem was warrantied, and they told me know. Then I told them the campaign number and suddenly it was warrantied and would cost me nothing. LOL They tried.
In all fairness they did do a good job!
I just had the tank replaced for the same issue in my wife's 08 Liberty. It is a known well documented issue, and Jeep is offering a lifetime warranty for the problem. Skip the dealership, go to Jeep.com and chat with them, they'll give you the name of the campaign and all the info. Then go to the dealer. I had all the info, called the dealership and asked if my problem was warrantied, and they told me know. Then I told them the campaign number and suddenly it was warrantied and would cost me nothing. LOL They tried. In all fairness they did do a good job!
^^x2 go to the dealer prepared and with printed info otherwise they claim to know nothing about it.
I went to Jeep all I could find is the following no reports about active campaign at all...
Safety Recalls (What is a Safety Recall? Learn More)
StatusChrysler Recall #NHTSA Recall #Recall DateSafety Defect/Non Compliance Description and Safety RiskRepair DescriptionRecall StatusReimbursement
J30 09V-436November 03, 2009THE TRANSMISSION FLUID MAY OVERHEAT UNDER CERTAIN DRIVING CONDITIONS CONTINUOUS OPERATION UNDER THESE CONDITIONS MAY CAUSE THE TRANSMISSION FLUID TO BOIL OVER AND COME IN CONTACT WITH HOT ENGINE OR EXHAUST COMPONENTS. THIS COULD CAUSE AN UNDERHOOD FIRE WITHOUT WARNING. THE CABIN COMPARTMENT NODE (CCN) MUST BE REPROGRAMMED TO ADD A TRANSMISSION TEMPERATURE WARNING FEATURE TO THE VEHICLE. AN ADDENDUM WILL ALSO BE PLACED IN THE OWNERS MANUAL EXPLAINING THIS NEW FEATURE. INSPECTED Submit Reimbursement
J24 09E-044July 14, 2009THE MOPAR BRAND TOW BAR PURCHASED FOR USE MAY ALLOW THE TOWED VEHICLE TO BECOME DETACHED FROM THE TOW VEHICLE. THIS CAN RESULT IN A CRASH WITHOUT WARNING. THE CROSS TUBE, VERTICAL HITCH PINS, HAIR PINS, HORIZONTAL HITCH PINS, FRAME MOUNTING BRACKETS, AND FASTENERS MUST BE REPLACED REPAIRED Submit Reimbursement
K13 10V-236June 08, 2010THE FRONT INNER FENDER LINERS MAY DETACH OR SAG ALLOWING THE FENDER LINER TO CONTACT ONE OR MORE BRAKE TUBES. CONTINUOUS FENDER LINER CONTACT WITH THE BRAKE TUBE(S) COULD RESULT IN A HYDRAULIC LEAK AND REDUCED BRAKING PERFORMANCE. THE LOSS OF BRAKING PERFORMANCE COULD CAUSE A CRASH WITHOUT WARNING. THE FRONT INNER FENDER LINERS MUST BE TRIMMED TO PROVIDE ADEQUATE CLEARANCE TO THE BRAKE TUBES AND CERTAIN FENDER LINER FASTENERS MUST BE REPLACED. ALSO, THE BRAKE TUBES IN THE AFFECTED AREAS MUST BE INSPECTED FOR DAMAGE AND REPLACED IF NECESSARY REPAIRED Submit Reimbursement
Viewing 3 of 3 total recalls
Campaigns (What is a Campaign? Learn More)
There are no outstanding campaigns for the above listed VIN
StatusChrysler Recall #NHTSA Recall #Recall DateSafety Defect/Non Compliance Description and Safety RiskRepair DescriptionRecall StatusReimbursement J30 09V-436November 03, 2009THE TRANSMISSION FLUID MAY OVERHEAT UNDER CERTAIN DRIVING CONDITIONS CONTINUOUS OPERATION UNDER THESE CONDITIONS MAY CAUSE THE TRANSMISSION FLUID TO BOIL OVER AND COME IN CONTACT WITH HOT ENGINE OR EXHAUST COMPONENTS. THIS COULD CAUSE AN UNDERHOOD FIRE WITHOUT WARNING. THE CABIN COMPARTMENT NODE (CCN) MUST BE REPROGRAMMED TO ADD A TRANSMISSION TEMPERATURE WARNING FEATURE TO THE VEHICLE. AN ADDENDUM WILL ALSO BE PLACED IN THE OWNERS MANUAL EXPLAINING THIS NEW FEATURE. INSPECTED Submit Reimbursement J24 09E-044July 14, 2009THE MOPAR BRAND TOW BAR PURCHASED FOR USE MAY ALLOW THE TOWED VEHICLE TO BECOME DETACHED FROM THE TOW VEHICLE. THIS CAN RESULT IN A CRASH WITHOUT WARNING. THE CROSS TUBE, VERTICAL HITCH PINS, HAIR PINS, HORIZONTAL HITCH PINS, FRAME MOUNTING BRACKETS, AND FASTENERS MUST BE REPLACED REPAIRED Submit Reimbursement K13 10V-236June 08, 2010THE FRONT INNER FENDER LINERS MAY DETACH OR SAG ALLOWING THE FENDER LINER TO CONTACT ONE OR MORE BRAKE TUBES. CONTINUOUS FENDER LINER CONTACT WITH THE BRAKE TUBE(S) COULD RESULT IN A HYDRAULIC LEAK AND REDUCED BRAKING PERFORMANCE. THE LOSS OF BRAKING PERFORMANCE COULD CAUSE A CRASH WITHOUT WARNING. THE FRONT INNER FENDER LINERS MUST BE TRIMMED TO PROVIDE ADEQUATE CLEARANCE TO THE BRAKE TUBES AND CERTAIN FENDER LINER FASTENERS MUST BE REPLACED. ALSO, THE BRAKE TUBES IN THE AFFECTED AREAS MUST BE INSPECTED FOR DAMAGE AND REPLACED IF NECESSARY REPAIRED Submit Reimbursement
I think it's just a TSB. Not a recall. But it extends the factory warranty for that item.
Here ya go: It was already posted by worth repeating.
SERVICE BULLETIN: 14-001-13 - 2007 - 2008 (JK)Wrangler - Fuel Spit Back During Refuel
SYMPTOM/CONDITION:
DIAGNOSIS:
If you have an aftermarket skip plate on the gas tank remove it and put it back to the way it came. There is no charge! Good luck, let us know how you make out.
My 2011 does this pretty regularly. Will have to see if I can talk to someone at Jeep about getting that rectified, as my current solution is that I typically just stop about 1 gallon from full whenever I gas up.
That's what I was doing for a long time. Then one day it started tripping the pump and spitting gas a few seconds after I started pumping it. That put me over the top.
My '06 TJ did the same thing. I would try to wash it off when I can and try slowing the pump down when getting near full. It can be really bad for your paint overtime. My TJ started rusting in that same area.
1 - 17 of 17 Posts
