I broke the upper bolt on my thermostat housing earlier today and was wondering if anyone knew the exact size they are? and what type I should get? Thank you.
Personally for stuff like that I like to get the oem bolt from the dealer but I can be a little ocd lol
Take the broken parts to your local hardware store and match em up.... should be real easy...
Fwiw if the bolt threads properly into a x size nut then it is an x size bolt.... grade 5 will be fine.... this isn't something that needs to be real tight.
98 TJ 4.0 Auto, 97 TJ 4.0 Manual, 98 TJ 2.5 Manual
I just had the same thing happened to me and I went to the local hardware store and just got a bolt that matched and it works fine. No need for expensive stealership bolts
The delaers bolts aren't magical bolts, even if you went to the dealer chances are they would walk out to the shop & grab a new one out of the bolt bin. Take the other bolt & go to the hardware store.
Dealers don't have bolt bins... they have way overpriced individual bolts in plastic bags with part numbers....
As I said my reason for dealer bolts is just my ocd.... it just annoys me having mismatched hardware...
I told him to go to the hardware store n match em up
No need to keep harping on the dealer thing
In the shop they have a bolt bin.
Buying 2 new bolts will take care of the OCD thing, which I get, btw.
