1 - 20 of 23 Posts
Drives by Braille
Measuring Bolt Patterns
Jeeps with 5 on 4.5" Bolt Pattern:
* 84-01 Cherokee (XJ)
* 86-92 Comanche (MJ)
* 93-98 Grand Cherokee (ZJ)
* 02-06 Liberty (KJ)
* 97-06 Wrangler (TJ)
* 87-95 Wrangler (YJ)
* 04-06 Wrangler Unlimited (TJ/LJ)
Jeeps with 5 on 5" Bolt Pattern:
* 06-08 Commander (XK)
* 99-04 Grand Cherokee (WJ)
* 05-08 Grand Cherokee (WK)
* 07-14 Wrangler (JK)
* 07-14 Wrangler Unlimited (JK)
Jeeps with 5 on 5.5" Bolt Pattern:
* 46-86 CJ (All Models)
* 63-73 Full Size Cherokee/Wagonner (SJ)
* 62-71 Galdiator Series Truck (All Models)
Jeeps with 6 on 5.5" Bolt Pattern:
* 74-83 J-10 Series Truck (All Models)
* 74-83 Full Size Cherokee/Wagoneer (SJ)
Jeeps with 8 on 6.5" Bolt Pattern:
* 74-83 J-20 Series Truck (All Models)
I think I got the most popular ones. :D
Jack Lives Here!!!
good info...this should be a 'sticky'. :insert thumbs up smilie here (why doesn't WF have a thumbs up smilie?):
Noted about smilie and moved and stuck this thread in the FAQ/Sticky section.
Nice work AZ.
Thanks AZ. Is backspacing of all wheels the same within 5x4.5 the group?
The Jeep actually has old Ford Explorer wheels on it. I need to remedy that quickly.
Thanks again.
Drives by Braille
If its an OEM wheel the backspacing is anywhere from 5-5.5"... after market wheels go anywhere from 3.25-4.5"
Nice info and noted for future use. Looking at trailers and want to use the same pattern as my Jeep.
wondering if my JK wheels would fit on my Dodge Ram (2014)
what do the numbers mean?
Thanks this is an excellent tool while I am looking for my wheels.... but I have a question..... When people say 5 on 4.5 what does the 5 mean and what does the 4.5 mean?
Hi guys and girls!
Hope it's okay to update this already great sticky with some additional bolt pattern measurements for JEEP.
Here's a comprehensive bolt pattern guide for most JEEP vehicles up to model year 2018, enjoy!
JEEP Cherokee SJ:
  • Year: 74-83
  • Bolt pattern: 6/139,7
  • Offset: 10 mm
  • Centerbore diameter: 108 mm
  • Stud size: Lug nuts 1/2"
JEEP Cherokee XJ:
  • Year: 84-01
  • Bolt pattern: 5/114,3
  • Offset: 32 mm
  • Centerbore diameter: 71,6 mm
JEEP Cherokee KJ (Liberty):
  • Year: 02-07
  • Offset: 42 mm
  • Stud size: Lug nuts 12x1,50
JEEP Cherokee KK (Liberty):
  • Year: 08-13
  • Offset: 42 mm
JEEP Cherokee KL:
  • Year: 14-18
  • Bolt pattern: 5/110
  • Offset: 42 mm
  • Centerbore diameter: 65,1 mm
  • Stud size: Lug nuts 12x1,25
JEEP CJ / Willys Jeep / AMC Jeep (all models):
  • Year: 44-86
  • Bolt pattern: 5/139,7
  • Offset: 10 mm
JEEP Comanche MJ:
  • Year: 85-92
  • Offset: 32 mm
JEEP Commander XK:
  • Year: 06-10
  • Bolt pattern: 5/127
  • Offset: 50 mm
JEEP Compass (gen 1):
  • Year: 07-17
  • Offset: 40 mm
  • Centerbore diameter: 67,1 mm
JEEP Compass (gen 2):
  • Year: 17-18
  • Offset: 40 mm
JEEP Gladiator SJ:
  • Year: 63-73
  • Offset: 10 mm
JEEP Grand Cherokee ZJ:
  • Year: 93-98
  • Offset: 25 mm
JEEP Grand Cherokee WJ:
  • Year: 99-04
  • Offset: 50 mm
JEEP Grand Cherokee WK:
  • Year: 05-10
  • Offset: 50 mm
JEEP Grand Cherokee WK2:
  • Year: 11-18
  • Offset: 50 mm
JEEP Patriot:
  • Year: 07-16
  • Offset: 40 mm
JEEP Pickup SJ / J10:
  • Year: 74-88
  • Offset: 10 mm
JEEP Pickup SJ / J20:
  • Year: 74-88
  • Bolt pattern: 8/165,1
  • Offset: 10 mm
  • Centerbore diameter: 120,9 mm
  • Stud size: Lug nuts 9/16" (18 UNF)
JEEP Renegade:
  • Year: 15-18
  • Offset: 40 mm
JEEP Wagoneer / Grand Wagoneer SJ:
  • Year: 63-73
  • Offset: 10 mm
  • Year: 74-92
  • Offset: 10 mm
JEEP Wrangler YJ:
  • Year: 87-95
  • Offset: 15 mm
JEEP Wrangler (all models) TJ:
  • Year: 97-06
  • Offset: 25 mm
JEEP Wrangler JK:
  • Year: 07-17
  • Offset: 44 mm
JEEP Wrangler Unlimited JK:
  • Year: 07-17
  • Offset: 44 mm
Notice that a bolt pattern can also be called lug pattern, pitch circle diameter / PCD, stud pattern, etc.
USEFUL INFO! All of the bolt pattern measurements are in metric in the above list, if you'd like to convert them to inches/SAE, just divide it with 25,4 mm (which is equal to one inch). For example, 5x127mm in metric = 127 mm / 25,4 mm = 5x5" in inches and 5x114,3 = 114,3 / 25,4 = 5x4,5". The first number only describes how many bolts that are used.
Please post any errors you may find, or if I have forgot any model that should be added to the list.
You'll find more bolt patterns for other car makes and models at www.bolt-pattern.com, welcome.
..and with that said I will probably get thrown out for all eternity, for mentioning my website :( ? Would be awesome though if, well, I didn't get banned.
Have a lovely day! :huglove:
Best regards,
Bolt-pattern.com
1 - 20 of 23 Posts
