A couple of days ago i got in my 2015 wrangler,turned the key and while all the lights came on the jeep wouldn't start. not even a click from the starter.
Removed the key and tried again... still no go.
Got out,opened the hood and tried again and it started right up lie normal.
hasnt happened since then.
About 3 weeks ago I had the security light come on when driving. It shut off when I stopped the car and didn't come back on the next time I drove. It came on again about a week after the first incident and same thing. I'm thinking they may be related.
Possible key issue? bad ECM?
Anything I should try?
Code reader? Clean battery terminals and then re-secure them. Battery could be in its final days...but a good indication of that is weak cranking. I'm sure others here have some great ideas for you.
Start with the easy fix first. Make sure your battery is fully charged and then test It. Once you have illuminated the battery you can move on from there.
