1 - 20 of 42 Posts
Sponsoring Vendor
We carry LED bulbs for replacement of your Wrangler's fog lights or DRLs, in all major sizes. They are available in HP, XP, and XML styles. This will make your fog lights a nice bright white that closely matches factory HIDs! Just simple plug and play, replace the bulb and you are good to go!
We carry the brightest, highest-quality bulbs at the lowest prices. Your order will ship same day, and we're here if you need us for support and service. And we do not raise the prices to astronomical levels- We're breaking that market trend, and offering you great, low prices, every day. These LED bulbs are designed by us here in St. Louis, and every bulb carries with it a three-year limited warranty.
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb, compared to the factory bulb.
  • HP48: (265 lumens) Lower than factory brightness.
  • XP80: (510 lumens) Considerably brighter than stage 2 (not available for all vehicles). Great match with factory HID's
  • XML2: (1410 lumens) NEW! Much brighter than factory. These are bright!
Please note that most LED fog lights are intended for cosmetic purposes only, and will not project light in the same way that the factory bulbs do. Your car will look great at night, but if you are looking for higher output, we strongly recommend using an HID conversion.
*XML2 available in 3000K Yellow / 4000K / 5000K / 6000K color temperatures
These bulbs are made up of a quality plastic connector to slide right into the plug, as well as high durability terminals. A load resistor is embedded to prevent blowing the LEDs from voltage surge, and a diode is implanted to protect the LEDs from reverse polarity. The LED is wired for 12V operation, the kind found on all modern vehicles.
Included in your order is TWO BULBS (to fit your Wrangler).
All of our products come with a 30-day satisfaction guarantee and a 3-year limited warranty.
Click below for more info or to order:
1997-2006 Wrangler
2007-2009 Wrangler | 2010-2016 Wrangler
XP80 Output Shots:
1997-2006 Wrangler |
If you have any questions, please don't hesitate to post, PM, email [email protected] or call: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thanks for looking!
Nick C.
Im confused. For the link posted, for $40 which bulbs are we getting? Is it the HP 48, XP90 or the XML2's?
Sponsoring Vendor
The listing has each bulb model option available
HP48's are $40/pair
XP80's are $90/pair
XML2 is $120/pair
Jeep Wrangler LED and HID Lighting
Feel free to give us a call if you have any questions about our products or lighting in general: (314) 205-3033
Thank you,
Nick C.
Thanks Nick!
Huh? My LEDs in my fogs are 10 times brighter then the oems that were in it
Sponsoring Vendor
That note is more of a reference to older SMD style LED fog lights, which won't produce nearly as much output as newer style LED fogs that utilize high-powered LED components.
Our XML2 for example, makes 1,420 lumens (measured), which is significantly more than factory halogen bulbs.
Nick C.
ok that makes sense. The factory Wrangler fog bulbs are not halogen btw
Sponsoring Vendor
Discussion Starter · #19 ·
http://www.youtube.com/watch?v=hn6Re02LRUw
Diode Dynamics: NEW! Stage Series Light Bars
Introducing STAGE SERIES LED lighting! Inspired by the needs of a professional rally driver, these light bars have been designed for maximum functionality, with compact size, cutting-edge TIR optics, and a useful beam pattern, all in a highly durable package.
-Advanced TIR (total internal reflection) optic
-Slim design, for easy mounting
-Available in driving or wide beam patterns
Sponsoring Vendor
Discussion Starter · #20 ·
Our Stage Series Light bars are available in Amber as well! Here's the Driving and Wide output comparison shots!
Thank you,
Nick C.
1 - 20 of 42 Posts
