i have a 2007 wrangler x that im having trouble with fixing. first im having trouble filling tank cause gas pump shuts off all the time second it will satrt and then shut off likes it not getting gas or it just wont start but eventually it does third the fuel pump finally has been running even with key off and is draining down batery went to parts store and they suggested fuel pump relay and they had one but couldnt find where it goes nothing under hood looked like the relay they had or there was not one on description where do i go gotta get to work on monday and jeep is messed up please help
If I recall right, there was a recall on some of the earlier jks, for a fuel filler problem. You can go to jeep.com and under the owners tab, you can log in and check to see if your jeep has any recall issues.
