1 - 20 of 24 Posts
Sponsoring Vendor
Jeep Wrangler Reverse/Backup LED Bulbs! Several Model Options! Plug & Play Install
Jeep Wrangler Reverse Light LED
At Diode Dynamics, we carry a full line of LED bulbs, including three different model options for your Wrangler's reverse light or backup light bulb. We carry the brightest, highest-quality bulbs on the market, which we have designed in St. Louis, Missouri. Your order will ship same day, and we're here if you need us for support and service. Every bulb carries with it a three-year limited warranty.
Bulb Design
HP48: This bulb is non-polar, CK compatible, with 48 Epistar 3014 LED chips. Thanks to the cap on the top, the light from this High Power Bulb is shined backwards and away from the bulb, not straight out. This means the output is excellent, because it uses the vehicle's housing completely, which then shines the light much more uniformly.
HP11: Four side-firing 1.5W-rated Osram LED chips, and one 5W-rated LED chip on top, which is projected by a lens for maximum effective brightness. The bulb is housed in a machined aluminum casing, which provides superior heat diffusion for long life.
XP80: Each of the four sides of this bulb contains three 5W-rated chips, and the top is fitted with four more under a projector lens. This is the brightest self-contained automotive LED bulb on the market, and is housed in an aluminum casing with a textured finish for maximum heatsinking properties.
Included in your order is TWO BULBS to fit your Jeep Wrangler model year selection.
COLOR
These LEDs illuminate in a crisp, cool, bright, white hue for maximum light output.
BRIGHTNESS
Diode Dynamics offers several brightness options so you can choose what fits you best. These options are listed by the design and the lumen output of each bulb:
HP11: Slightly higher brightness than OEM bulbs. (310 lumens)
XP80: Much brighter than OEM bulbs. These are bright! (510 lumens)
Lumens. BUYER BEWARE! Most sellers just provide "calculated" lumen numbers, based on the maximum potential brightness of the LED chips on the bulb. For example, if a bulb has five 10-lumen chips, they will rate it at 50 lumens. However, this is not accurate, as the design of an LED bulb does not get rid of heat fast enough to run the LEDs at maximum.
These "calculated" lumen ratings are much, much higher than the true, measured light output, so it will look like competitors' bulbs are brighter than ours. This is because Diode Dynamics does not provide inflated "calculated" numbers; we believe it is misleading. We test the actual brightness of the bulbs in our lab, to provide real lumen output measurements. Our measurements are accurate, but they are usually much lower than the misleading "calculated" figures.
QUALITY
LED Components. Diode Dynamics uses only the highest quality LED chips in the production of its bulbs. This means only brand-name suppliers such as Epistar, Cree, Osram, and Samsung.
While Diode Dynamics bulbs may look the same as others on the market, most copycat bulbs use economy-grade LED chips in order to reduce costs. This greatly reduces the reliability and overall brightness of the bulb when you compare it to Diode Dynamics.
Construction.
Although LED technology allows for extremely long bulb life, the market is flooded with cheap LED bulbs that fail prematurely due to inferior construction. The worst enemy of LEDs is excessive heat, and when bulbs are not designed properly, they do not disperse heat as well, leading to premature failure.
Off-brand, cheap bulbs exhibit poor solder uniformity, high levels of flux in the solder, uneven chip placement, low-gauge terminal wires, poor assembly, and bulbs held together with inferior adhesives. At best, solder joints will crack and fail on low-quality LEDs after a few weeks of use. In the worst case, these bulbs can damage housings as the extra flux and adhesive evaporates and creates a residue on the lens of the housing.
Diode Dynamics bulbs are produced with modern, computerized equipment, and only the best materials, to ensure complete uniformity, high quality, and long bulb life.
All Diode Dynamics products come with a 30-day satisfaction guarantee and a 3-year limited replacement warranty.
Questions? Feel free to ask here, PM, email [email protected] or call us: (314) 205-3033
*PM us for the free-shipping code* (U.S. forum members only)
Thank you!
Nick C.
Diode Dynamics
I love Diode Dynamics. I put their LEDs in our Mustang and they were a HUGE improvement over the stock lights!
We'll soon be ordering lights for the JL cabin and reverse lights.
Sponsoring Vendor
Thank you so much for your continued support! We are extremely excited about the JL Wrangler.
Lots of exciting things in the works over at our engineering building :bop:
Nick C.
Sponsoring Vendor
Jeep Wrangler JK Diode Dynamics Reverse Light Bulb LED Cool White Pair 2007-2018 Installation
Here's an installation video courtesy of our friends at CJ Off-Road showing how to remove the factory tail lights and install Diode Dynamics' LED replacement bulbs.
Thank you,
Nick C.
So, with three different outputs, how do you determine which you want for reverse lights? Price point? or just preference? Is there a law or requirement of some kind? Right now I have the stock back up lights which are, shall we say, sadly lacking!
Sponsoring Vendor
It's all personal preference, and based on what you are looking to spend. I always like to joke that the brightest models pay for themselves the first time they prevent you from backing into your mailbox.
You don't have to worry about blinding other drivers, or violating any legal requirements with any of our model options either.
Thanks!
Nick C.
Ok looks like on my next paycheck I might be getting some of these instead of whole new tail light assemblies! Awesome!
Sponsoring Vendor
Discussion Starter · #13 ·
Our Black Friday sale starts NOW! Today through Monday, 12/2/2019, save 20% on all LED upgrades including our Backup Light LED Bulbs by entering coupon code "BLACKFRIDAY" at checkout!
Jake H.
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday 12/2/2019. Cannot be combined with other coupon codes.
Sponsoring Vendor
Discussion Starter · #15 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 12/2/2019, you can use coupon code "BLACKFRIDAY" at checkout for 20% off your entire order of lighting upgrades, including our NEW SS3 LED Pods!!! Don't wait, this sale ends TONIGHT!
Jake H.
Diode Dynamics
Sponsoring Vendor
Discussion Starter · #16 ·
Our July 4th sale starts NOW! Today through Monday, 7/6/20, save 15% on all LED upgrades, including our Backup Light LED Bulbs by entering coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.
Sponsoring Vendor
Discussion Starter · #17 ·
Don't miss your chance to save on all LED upgrades! Through Monday, 7/6/20, get 15% off all our LED upgrades for your ride, including our Backup Light LED Bulbs with coupon code "JULY4" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Monday, 7/6/20. Cannot be combined with other coupon codes.​
Sponsoring Vendor
Discussion Starter · #18 ·
Our Labor Day sale starts NOW! Today through Tuesday, 9/8/2020, save 15% on all LED upgrades, including our Backup Light LED Bulbs by entering coupon code "LABOR" at checkout!
Collin
Diode Dynamics
Sale ends 11:59 p.m. CST on Tuesday, 9/8/2020. Cannot be combined with other coupon codes.
Sponsoring Vendor
Discussion Starter · #19 ·
LAST CHANCE TO SAVE!!! Until 11:59 p.m. CST on 9/8/2020, you can use coupon code "LABOR" at checkout for 15% off your entire order of lighting upgrades, including our LED Backup Bulbs!! Don't wait, this sale ends TONIGHT!
Collin
Diode Dynamics
Sponsoring Vendor
Discussion Starter · #20 ·
Don't fear the backup! Our LED replacement backup bulbs not only give you a huge increase in nighttime vision, but they also give your ride a nice, modern cool white look!
Don't forget to PM us for free USPS shipping!
-Collin
Diode Dynamics
1 - 20 of 24 Posts
