dear jeep friends.
I need help.
I put a 4.2 ltr cherokee engine from 93 in my 91 wrangler.but did not use the injection system.just put I carb on the manifold,but the engine is not running edle,run too rich or too lean.some told me that I have to change the manifold,can anyone help me with advice.:confused:
where I can buy this kit.
kind regards.
overseas jeep freak
Are you sure it was a 4.2? Here the 91-95 were 4.0 in both the Cherokee and YJ. Either way, if you moved over the right parts, the block shouldn't matter. How much vacuum are you pulling at idle?
thank you for your reply.
it.s 4.0 high output engine that i used..
but the mainifold is not the same as stock engine,so i cant us the old intake manifold.
The Cherokee 4.0 doesn't really have any more power. Put a vacuum gauge on it and tell us what the reading is. Better yet, a youtube of the vacuum gauge.
