All I can pull up on the wide world web is 4dr springs going into 2dr rides. I'm looking at an AEV 3.5 set of coils off a JK that I would be putting onto my JKU.
How much ride height off the 3.5 am I looking at losing? AEV is known to be stiff so maybe not too much. I haven't read or,thought of any other concerns with it.
I know it's all about how stiff the springs are and not the actual length
I don't have specific data as far as spring rates. I have a AEV 2.5 with my jk I added around 300lb of weight not counting wheels and tires. it sagged roughly a inch. I would imagine they would be 2.5-3 for you with a slightly softer ride. Before I added the weight I had 3.5 and it was very stiff. 300 is not far off from the added weight of a JKU. If you're planning on adding armor and a winch I would recommend just getting 4dr sprigs.
I have an AEV 2.5" lift and on that one there are different part numbers for the 2 door vs the 4 door springs. I can't imagine the 3.5 and 4.5" lifts would be different. They also use a progressive rate spring.
Just talked to Eric at AEV. He basically made me answer my own concerns.. Lol.
After agreeing that I will lose ride heigh and that the springs are tunes for 2dr 's 4Dr's ; he said he would not recommend it.
Hmm, in not concerned about ride height as long as I'm still in a similar 2.5 range. I have spacers to use to compensate any weird angleage from 2dr tune to 4dr.
He didn't care to disagree that they might also sag at a rate faster once I mentioned that as well.. Not faster than the TF I've had on for,the past 3 years lol...
I think I'm going for it, I'll let you guys know how it turns out after install.
That just means a softer ride rate. Not a bad thing imo
