I have a 2014 Jk 2 door. It currently has Ebiach springs that has given the front roughly 3.25” of actual lift. It also has an adams DS and Core 4x4 front lowers.
I have unlimited access to an automotive shop with an alignment machine.
What should I set my caster at?
Start at 5 deg. Then check for vibes and freeway stability. Vibes require less and less stability requires more. Make sure the axles are centered and in line. The short wheelbase of the 2 door can make things more critical than the 4 door.
Anywhere from 4.5 to low 5's have always felt best and I like toe set on the lower end of the range.
Reactions: TRBOKEV
Yep, at least 4.5, not to exceed 5.0....
