Last week my check engine light came on. I thought is was for the 96K Maintenance. I was wrong. I took it to the dealer and got all the work done. When I picked up the jeep the guys told me the light was still on and that it kicked back a code to do with the transmission. I was told the mechanic who would normally troubleshoot the code was busy with other transmissions and could not look at my Jeep.
I told the guy the following items are also an issue:
1. Window controls in center no longer light up and the driver's window does not always go down.
2. Cruise control does not work
3. There is a ton of static in the radio
My Question is could they all be a related electrical issue? I plan on schedule the diagnostic but don't want to drop $1500+ on transmission work if that's not the root cause.
Any and all feedback is appreciated!
Thanks!
I wish you would have put the code that found by the dealer...
The symptoms you mentioned point to either a loose Negative battery connection, either on the battery or on the body/engine, OR TIPM failure.
As for the Cruise Control not working, Wranglers are also known for Clock Spring failure.
They did not give me the specific code just noted the torque converter. I checked the Battery terminals and body connection and everything was tight. Thanks!
Ok...Got another diagnostic from mechanic and the code is P0740. He explained everything. So now I'm looking at a new transmission!
Just doesn't seem right. I purchased it used from a Jeep dealer with 54k Miles, had it serviced a jeep dealer for the last two years and now with under 100k miles I'm told the transmission is bad.
It sucks, but transmissions (and other things) do go bad.
For what it's worth, I've never had a check engine light that comes on for scheduled maintenance (other than your typical "change oil soon" or things like that). Generally a check engine light means that a sensor has picked up something that is actually outside of spec. Sometimes it's just a bad sensor or a bad wire, but sometimes it's actually a mechanical repair that needs to be made.
I also remember when I was a kid in the late 70s/early 80s, if you got 100k out of a vehicle without it completely falling apart, you were very lucky.
Of course, back then you didn't pay $30k+ for a Jeep.
what year is your jeep? 2012 - 2015 JK's have a power terrain warranty for 5 year 100 000km
