2015 2dr jk auto. Regeared from 3.21 to 4.88 about 6 months (8k km on it since)
About a month ago I had the memory who did my gears install a new Adam's extreme duty rear driveshaft with new yoke. I already had an Adam's front driveshaft installer with factory flange. About a week or so ago I started hearing Clunking or clicking” when starting to move. I can replicate it when I rock my jeep back and forth. Seems to be coming from the differentials. I posted a link. Is this normal? Should I be worried?
Thanks
Sent from my SM-G950W using Tapatalk
I can't see the link to the video, but if something changed after the install, then it likely is not normal.
Did the mechanic re-set bearing preload when they installed the new yoke? Can you feel any radial play at the yoke?
Either way, I would bring it back to whoever did the installation to figure out what is wrong.
