21 - 40 of 160 Posts
:D 2008 "unlimited" Rubicon
LIFT: RC 2.5 all steel, no plastic
SHOCKS: RC9000XL (9 adjustments)
SYE/CVD--Nope
TIRES: Hankook LT295/75x16 (33.6")
WHEELS: ProComp 8089 Xtreme Alloy
Likes: I can't notice any difference in driving, just getting in and sliding out !!!
Dislikes:--NONE
I recommend the kit
:rofl::rofl: JIMBO
09 JK unlimited
TeraFlex 2.5" Budget Boost with Shocks
Likes: Perfect lift for a daily driver. Retains stability and is enough lift to accomadate 34" without rubbing.
Dislikes: None
Banned
Hmm- I have 2 reviews:
2009 JK 2-door, 6-speeds for both
1st up is the 2.5" Rough Country coil spring lift with their shocks. No pics anymore, as this kit is LONG GONE. Garbage. 100% JUNK. The first issue was in shipping- yeah, they forgot to. Then, the first set of rear springs starts to sag about an inch or two inside of a month. So, I call them up, and they send out new rears. Install those. They sag inside of a week! This is a base model, 2-door 6-speed softtop- you don't get much lighter! Stock bumpers, 33's. Unacceptable!
Grade: F---
Recommended: Oh, hell no!
Likes: They did give me a full refund, though, if nothing else... although they made me pay return shipping- jerks
2nd review:
3.5" Rock Krawler kit with Bilstein 5100's:
This was a cherry-picked kit. It's pretty much one of the X-Factor kits, minus the front uppers- don't have much use for those- that'd just add weight higher up- no thanks :)
Everything! Best Jeep ride and handling ever. Handles as well as my old Subaru Impreza on sweepers- still a Wrangler in the tight stuff, though :) Ride is better than stock by far. Decent instructions, and it went together like butta- 10.5 hours by myself with no air tools and on jack stands. GREAT support from a great (local to me) company. Lifetime warranty that COVERS abuse. They also go out and test everything they make- I really dig that. Brought up beer and pizza, and they helped me slap in their extended brake lines. Straight up the best purchase I've yet made in Jeepdom.
Dislikes:
The swaybar disco's tend to clink a bit if you don't shim them a bit (cost all of $.08 to do so), and the extended brake lines needed a bit of wrapping with electrical tape. Other than that, no complaints at all :)
Total lift:
Front- 4.5"
Rear- 4.25"
Running 35" KM2's on 15" Cragar Soft 8's
Would I recommend?:
Oh hell yes! Buy this kit, run the 5100's and you will LOVE your new JK :) Mark W.
Rough Country 3.25
LIFT: Rough Country 3.25" lift, with the addition of a complete set of Rough Country X-Flex Adjustable Control Arms and a JKS Adjustable Track Bar
SHOCKS: Rough Country Performance 2.2
TIRES: 35 x 12.5 Maxxis BigHorn's on stock 17 inch alloy's with 1.5" wheel spacers
LIKES: The cost of lift kit. Also, I am happy with the X-Flex adjustable control arms...but they are not included in the lift kit. So it's debatable if I should include that in the likes section. Regardless, they seem to be good quality and durable.
DISLIKES: Spring sag. The after market Rugged Ridge XHD rear bumper w/ tire rack and 35" spare caused 1.25" of sag in the rear. The XHD front bumper(without a winch) caused 1" of sag in the front. Running 35's with what amounted to 2" of lift after sagging caused my Jeep to bottom out the rear shocks on the bump stops when hitting moderate pot holes on the roadway. I ran it this way for about 2 months.
I have since swapped out the springs with Rock Krawler 3.5" front and rear springs...and let me tell you what a difference!! With the Rock Krawler springs my Jeep is experiencing very minimal sag despite the extra weight. It more than solved my bottoming out problem. The Jeep also rides 10x better....much "smoother" hitting bumps on and off the road.
WOULD YOU RECOMMEND: No. I would not recommend a Rough Country lift due to the above mentioned spring issues. However I would recommend their X-Flex adjustable control arms. I am a firm believer in you get what you pay for...there is a reason it's alot cheaper. Just my 2 cents.
I would recommend Rock Krawler springs in a heart beat...and I can only assume that the rest of their products are just as high quality.
MARGARET, 10-14-51\6-1-12
lift- teraflex 3 inch
shocks teraflex 9550
tires stock 17x 31
bds steering stablizer
likes. cost. jeep sits perfect. rides perfect even on the highway
performed awesome off road. plenty of ground clearance . very predictable handling.
dislikes- none yet
recommend- yes.
LIFT:OME+40 Coils
SHOCKS:OME LT shocks
TIRES/WHEELS:ATX Artillery 315x12.5 Toyo Open Country MT
Likes: Love the ride and the way it handles
Dis-Likes:NONE
Would You Recommend:Yes 100%. This being the +40 lift gained me ~4.5 inches. Lift need lower CA's,Front DS, ADJ TB's, ADJ sway links,ext brake lines....ect
Picture(s):
Rock Krawler 3.5 Entry Level
LIFT: 3.5 inch Rock Krawler Entry Level Kit
SHOCKS: Bilstein 5100's
TIRES/WHEELS: Sadly still the stock "bicycle" tires it came with. If only tires werent so much $$$$
Likes:Great look and stance. Install was easy and the instructions were straight forward. All the parts seemed sturdy and able to take a beating.
Dis-Likes: Required welding, this sucks for people trying to do it in their garage. The quick disconnects aren't the best but are better than nothing. The rear brake lines are a bit tight as is the ventilation tubing on the rear axle.
Would You Recommend: Most definitely. This is a great kit and the shocks make it a great setup. While I did list a few things that could be done better, for the price it's a great setup and even with those few items I would purchase it again.
Picture(s):
Lift= TeraFlex 2.5 coil #853100, Plus 1" puck in rear
Shocks= TeraFlex # 9550.
Wheels= 18" Moto Metals wrapped in Toyo Open Country MT's. 1.5" RC Hub-centric Spacers
Other parts= T.F. front adj. Trac Bar, JKS Disco's, Rear Trac Bar relocation bracket.
Likes= It realy flexes. It's super quiet. Very plush ride, (drive off a curb & barely feel it!). High quality and affordable
Dislikes= rear springs fall out of top pockets when you lift a wheel. Fixed problem with DIY over-extension straps.
Reccomend Lift= For sure
LIFT:
Skyjacker 3.5"
SHOCKS:
hydro skyjacker shocks
SYE/CVD: Stock
TIRES/WHEELS:
Crager soft 8's 15"8"
BFGoodrich KM 2's 35X12.50XR18
You get way more looks and people always tell me they like my jeep at the gas station.\ Love the ground clearence with this short wheel base. I really couldnt tell a diffence in the riding between stock and having it lifted.
CHICKS DIG IT!!!!!
Dis-Likes: The 35's drained my jeep of power. Its not as bad as i thought it was gonna be but there a differnce.
WITHOUT A DOUBT!
Picture(s):
LIFT: Rock Krawler 2.5 Stock Mod With Rock Krawler Disco's
SYE/CVD: Stock
TIRES/WHEELS: 35x12.5x17 Goodyear Wrangler MTR/K's on ProComp 7089's 17x9 - 4.75 BS
Likes: Awesome lift, easy install, great ride - Progressive Rate Front Springs and most of all... Adjustable Front Trackbar - and relocation for rear... Solid as hell...
Dis-Likes: None at all
Would You Recommend: By all means and already have numerous times...
Picture(s):
2.5" rc spacer kit
This kit was the only way i was going to do a spacer kit ALL STEEL ! Me and my dad installed this kit in the garage in 2 hours and 15 minutes using the scissor jack 2 jack stands and a ratchet with 4 sockets. So far it is everything i expected . Would recommend this product if a budget lift is what you are looking for . Actually only got about 2" overall and the kit is 2.5 in the front and 2 in the rear for a more level stance although i liked it the way it was . All that said heres a pic . Land vehicle Vehicle Car Jeep Automotive tire
Land vehicle Vehicle Car Tire Automotive tire
LIFT: 3.5" Rock Krawler Entry Level Suspension Lift
SHOCKS: Bilstein 5100 Series
SYE/CVD: Stock
TIRES/WHEELS: 35x12.50R18 Nitto Trail Grappler / HELO Chrome 791
Likes: Looks and Drives great!!! Ride is a little rougher than stock, but not much.
Dis-Likes: None... Looks Awesome!!!
Would You Recommend: Definitely!!! Would suggest putting a steering stabilizer on. Gets squirrely at 70+ and on uneven roads. I'm adding a Bilstein stabilizer as soon as I can.
Picture(s): Can't figure out how to upload Pics... Sorry
Lift- rock krawler 3.5" m.o.r.e. 1" body lift
Shocks waiting for the new rock kralwers now some junk one I had hanging around
Sye/cvd stock but soon to be changed
Tires/ wheels. 40" pit bulls rockers with 17 x 9.5 spyderlock wheels
Likes rides great and handles offnroading very well
Dis-likes none
Recommened yes best warranty in the business you break they replace it.
LIFT:
Rough Country X Series 4" Suspension Lift $1199.00 complete
Front: Lifted coil springs, upper and lower adjustable control arms with X-Flex joints, adjustable track bar, quick disconnects, and stainless steel brake lines.
Rear: Lifted coils springs, upper and lower adjustable control arms with X-Flex joints, track bar drop bracket, sway bar links, and stainless steel brake lines.
SHOCKS: (4) Rough Country Performance 2.2 series shocks included with lift kt. Dual Rough Country Steering Stabilizers
SYE/CVD: Tom Woods 499.00/ea - being a 2DR lifted over the 2.5" threshold it was necessary
TIRES/WHEELS: 5x 35" Dick Cepak Mud Country @ 304.00/ea mated to 5x 17x9" Mickey Thompson Classic II Aluminum Rims (replaced the Rubicon 32" BF Goodrich Muds, coupled with 5x Mopar Black Aluminum Rims)
OTHER: 5.13 "purple" gears @ 800 per axle installed, ARB Iron Differential Covers (180/ea), Skid plates (oil pan, evap canister, gas tank, transfer case), River Raider breather kit (49.00), AEV Snorkel with Ram Air (349.00), Bushwacker Flat Fenders (599.00)
EXISTING: Mopar front winch bumper with fog lamps and crush cans, Mopar rear bumper, Mopar swing away tire carrier with HiJack Mount, 12.5k winch, KC Highlighter 400k x 2, D hooks and mounts front and rear x 5
Likes: It looks like it should have always, coming from the factory. Well balanced look, professional install courtesy of Steve at Jeep Home Steves Jeep Country - Epsom NH // The ride is a little more top heavy feeling due to the raised CG, stiffer than stock but no unacceptable. On the highway the tires hum but not like I remember mud tires from my past by any stretch. The 5.13 gears breathed new life into this motor, even coming from 4.10's with 32's. Plenty of usable power through the power band, 2850 rpm indicated @ 65mph in 6th gear) First gear has more legs now, so you can actually start off in it instead of 2nd all the time.
I used an AEV Procal (150.00) to calibrate the gears and tire change. Yes, do not just punch in the tire size, it will not yield an accurate result (ie 35" Mud Country tires are actually 33.75 inches tall). Gas mileage changed imperceptibly, though it's still early. In any event I highly recommend the Procal - remembering the skid control, ESC, ABS and everything else keys off the speed of the vehicle - if the speedometer is inaccurate, everything else will be also.
Dis-Likes: I'm old - the 6" increase in ride height, coupled with an unyielding roll bar means this gorilla (6'5") has to learn a new way of entering and exiting ;)
Would You Recommend: Absolutely! and I would recommend consulting someone who does this work for a living also, Iearned a few new things along the way that led to a solid, stable platform. (Thanks Steve).
Look for the buildup by following this link ---> http://www.wranglerforum.com/f33/the-buildup-in-on-78914.html ... plenty of pics before and after :dance::dance:
Now time to figure out how to pay for it :rofl::rofl::rofl::rofl::rofl:
AEV 4.5" Premium
2008 Jeep Unlimited
System: 4.5" AEV Premium
Shocks: Rancho RS9000xl
Driveshafts: Tom Wood's 1310's front & rear
Add'l: Teraflex Monster Arms, 37/13.5R17 Nitto Mud Grapplers, TeraFlex Disconnects...
Likes: Excellent on-road ride. :thumb: Very stable at highway speads. Corners much better than stock.:appl: Firm ride w/out harshness.
Dislikes: Limited flex, but this may be a result of short shocks and not the AEV system.
I would recommend this system to Jeepers who spend more than 50% of your time on-road. I get out wheeling 3+ times a month and enjoy the set up I have. I will be working on the flexibility, but the ride is spot on.
JEEP: 2010 2 door
LIFT:
Rubicon Express 3.5in for 2 door - (2.5in front and 3in rear after settling)
SHOCKS: Rubicon Express from the kit
SYE/CVD: stock
TIRES/WHEELS:
Unfortunatley still stock!
EXTRAS:
Poly Performance front adjustable track bar, Teraflex rear axle mounting track bar relocation bracket, Poly Performance front disconnects suit 2 to 4in lift, Poly performance rear links to suit 3 to 5 in lift shortened by 40mm, Poly performance front damper relocation bracket (since removed as it doesnt fit the 2010 model properly and the draglink hits the damper mounting bolt), home made 3in rear brake line extension brackets.
Likes: very stable on road, sits nicely
Dis-Likes: little bit stiff on road for the short wheelbase, havent been able to get offroad with it yet due to waiting for little bits to be finalised and torrential rains...
Would You Recommend: Yes, but not really much point since RE have closed their doors!
Picture(s):
LIFT: 4.5" BDS short arm
SHOCKS: BDS
SYE/CVD:Stock
TIRES: 35x12.5x18 BFG KM2
WHEELS: American Eagle 18" 079 Super Finish Black (5x5, 4.5" backspacing)
Likes:Lifetime Warranty: The stance is awesome, plus the ride is better than stock.
Dis-Likes:None
Would You Recommend:Absolutely
Picture(s):
I AM THERE4 I JEEP
LIFT: Daystar 3/4" Comfort Ride Lift Kit
SHOCKS: Stock 2010 JK
SYE/CVD:Stock 2010 JK
TIRES: 255/75/17 Nitto Trail Grapplers
WHEELS: 17" Ultra Rogue 175
Likes: Lifetime Warranty: The stance if fantastic and it rides just as smooth if not smoother than before the lift. Very easy install and only takes about 2hrs. An extra pair of hands is highly recommended.
Dis-Likes: None
Would You Recommend:Yes especially for those who want to run 32" tires. This lift looks fantastic and gives a great stance to the JK with stock tires. Better height and better looking no doubt.
Picture(s):
Before
After
