will stock wheels and tires from a JK fit on a TJ (no lift) with the correct spacers to match the bolt pattern of course
JEEP OUT
I would say as long as it's a 265 or 31" or under, should be fine with correct bolt pattern adapter.. Good luck, I'll keep up to see what others have to say....:popcorn:
MOTJ, I'm about to put 18" JK wheels like yours on my stock 2005 TJ, with no lift and 1.25 adapters. Tires will be approx 32. Do you get any rubbing at all with yours? My on figuration will be almost exactly the same.
One small spot that still hasn’t broken through the paint, the added .250 with your spacer/adapters might stop this and I’ve read of some kind of simple stops being added to the steering.
Without a lift don’t count on off roading and not having your front fender flares rub.
