1 - 11 of 11 Posts
My dad as a 12 JK Sport S and is getting new rims and tires. I'm looking to put those on my stock 95 YJ. I know the bolt patter went from a YJ at 5-4.5 and the JK 5-5. Anyone know a good set of adapters and know off hand what else might need to be done? Will these tires even fit? He has the 255/75-17s
Mr Jeepy of California
Well in my honest opinion if I was you the best way to go about this is get an RC 4 inch lift kit and anything up to 33's will fit. Really just depends on the size of tires, I'm guessing you have 28's on so a lift is the best way to go about it. Depending on the JK tires and your engine you might not be able to use 5th gear.
We needs more pictures and information. :popcorn:
did a quick search and found that the tires are about 32", so they won't fit without a lift
Yea your gonna need a small lift to tuck those bad boys under there, not only are you adding 2 inches of wheel but probably 2 inches of tire or so. Not gonna be able to tuck those bad boys with out a small lift but to answer your question... these are the best... and you will need 2 sets, total of 4 spacers.
Spidertrax WHS-002 - Spidertrax Wheel Spacer Kit for Jeep® Wrangler YJ, TJ, Unlimited, Cherokee XJ, Comanche MJ, Grand Cherokee ZJ & Liberty KJ with 5x4.5" Bolt Pattern - Quadratec
Thanks. I'll have to check it out!
I have a '95 YJ with a 2" Zone OffRoad suspension lift and the wheels/tires off my '12 JKU Sahara (P255/70R18) on 2" spacer adapters.
The offset of your stock YJ wheels are likely around +25, but the JK 17" & 18" are +45 (they will be closer to your leaf springs and probably rub when turning lock to lock). I could have went with 1.5" spacer adapters, but with my wider flares they would have been tucked in too far for my taste. Also, I put the wheels on a few days before the lift... for street use they didn't rub, but the 33" DuraTracs I used temporarily rubbed in the rear the moment I came off the pavement... guessing the 32" JK Sport GY Wranglers on 17's would with little flex as well.
I got my spacer adapters on eBay, think it was around $135 for a set of 5.
Looks great! Do you know the seller from eBay so I can check them out?
Be careful of where you buy your spacers if they are not well built they will come lose. I suggest you spend the money and get the Spidertrax. Some times you need to spend the money op front to stop problems later.
1 - 11 of 11 Posts
